georgect
I read in another forum that a guy has faked out his washer by using a hose to saturate the clothes in the washer before the washer is started.
The washer will sense the load is heavy and supposedly add more water.
Has anyone every tried putting saturated wet clothes in the washer before it's started to see if it does in fact make the washer fill with more water?
It would be cool to see the results here with different washers and if it works with all washers.
