A308
aircub
Jun 6, 2019
115
Huntington, AR
I just picked up a Maytag A308 and it needs a drain hose. I cant find one on ebay does anyone know where I might find one?
Thanks,
darren
Congrats on your Maytag find. I would just get an aftermarket reinforced universal drain hose for it. Just make sure it’s not a cheap rubber one that kinks or collapses easily.
year built
can anyone help with the date of manufacture and does this model have two speed or not it is clean as the day it was new and looks real low milage?
Born
June, 1978
Try and get a hold of a genuine Maytag drain hose off of the last generation Dependable Care line from the mid 2000's. An old school mom and pop appliance store will probably just let you take one off an old machine that was exchanged for a new one.
Most commonly available universal drain hoses these days are corrugated and these machines don't jive well with them.
211704 F&P Washer Drain Hose
LOL, nope.  F&P doesn't use anything like that on their machines that I've ever seen.
Drain Hose For A MT DC Washer
Corrugated plastic will work just fine if it is large enough, it needs around a 1" inside diameter for the entire length.
MT switched to corrugated plastic hoses on these washers the last few years they built them with no ill effects.
You do not want a rubber hose like the ones Launderess said were posted on Ebay, that type of hose will kink and restrict water flow if you just look at it.
John L.
hose
I have just found a corrigated one at a local dealer he says it will work fine. thanks to all and will continue to keep my eyes open for an original one.
Thanks
