Aarrrgghh! Our microwave bit the dust!
whirlcool
Jun 29, 2005
9,618
Just North Of Houston, Texas
A few weeks ago our Kenmore dishwasher bit the dust, tonight the Kenmore Microwave bit the dust.
What happens is the unit sounds normal until the magnetron kicks in, then it humms very loudly and doesn't heat anything in the machine. I tested the unit with 1/2 cup of water. After 1 minute, the water was the same temp it was when I put it in. When you set it for defrost, the unit hums only when the magnetron is activated.
Over the past few months it has been popping a circuit breaker maybe once per month when you are entering your settings in the keypad.
Does this sound like a lost cause? The unit was a 1993 build.
Yes I agree. One doesn't get these thing repaired in that one fears radiation leakage.
IMHO m-wavers last less than ten years.
If your stove is gas, may I suggest an over-the-stove microwave/convetion oven? Much cooler for summertime cooking.
The stainless-steel interior makes for easier and more fearless scrubbing as well
Your problem is definately in the high voltage section. It could be something as simple as a shorted high voltage capacitor or diode up to a shorted magnetron which can be ugly. >Usually< not to hard to diagnose. Unplug it (duhh) and short the cap against the frame. (most newer HV caps have a built in bleed resistor but I've never learned to trust it...) With a good meter (9V battery or better set to Rx1000), you should find the diode will show continuity one way but not the other. If it shows both ways, it's bad. Some cheaper meters or ones with weak batteries will show infinite resistance both ways. The cap should not show shorted to case (Rx1000) from the terminals but should show several ohms momentarily then gradually return to infinite when measuring across the terminals. A good meter will have a capacitor check that will give you a microfarad reading to compare to the the rating. The mag should read less than 1 ohm across the terminals(scale Rx1) and no continuity to case (scale Rx1000).
Or you can buy a new one. As stated above, they can be insanely cheap but not always built as well. If you DO end putting in a new mag, just like a car with a new engine, the unit will probably heat things with the same speed it did when new. Be sure to check warranty with the new ones as many manufacturers are going to a 90 day.
RCD
Amana Radarange:
Well, my RRL-9TC seems to have bitten the dust. It worked fine for several weeks after I discovered it in the thrift store, then one night, its usual electronic hum changed to a loud roar. The circuit breaker blew. I have retired it for the moment until I can get some advice on whether or not it's fixable. Until then, I have to say that an old Radarange may not be the answer to a microwaver's prayer.
And to think...
that Karen and I were just snickering to ourselves because the microwave is black with silver trim and will match the new range and dishwasher and we'll still have everything match.
The Kenmore microwave was an above the stove model. It had a lot of features. As with normal people we only used a few of them.
I'd actually like to go with a nice over the stove hood and vent system that is vented to the outdoors, but the kitchen is so small in this house that counter space is at a real premium. ]
We have our old Litton microwave in the garage that still works, but it is missing the bottom glass plate. Is it still safe to use with that glass plate missing?
The only thing we use our microwave for is heating tv dinners right out of the freezer and maybe some frozen breakfast rolls in the mornings on occasion.
What kind of reputation do Maytag microwaves have? It seems strange to me in a way, our kitchen is soon becoming all Maytag. But we still have a Whirlpool washer & dryer. The main reason for this is Karen thinks that if all the kitchen appliances are the same brand the resale price may be a little higher when we go to sell the house, which may be soon!
So will you become "Maycool" or "Cooltag&quot
If you had asked me a year ago if we would ever have a Maytag kitchen I probably would have said "Hell no!". But the pricing and performance of our past Maytag dishwasher set the tone for it.
We are keeping the Whirlpool electronic set we have for the forseeable future, so I'll still remain Whirlcool.
Glass Plate
The glass plate serves a use. Without it, the microwaves don't reach the food from below, for one thing. The distribution pattern for ovens without a turntable is designed for and dependent on that reflection and scattering from the bottom plate.
I should think a simple elevation of the food in the microwave would solve the problem, like a microwave porous plate? ARC, by the way, usually has zillions of glass microwave bottom liners.
Back in 1996, I bought a combo microwave/grill/convection oven to make do because the new gas lines for my oven couldn't be laid in until after Christmas. It is 2008 and I am still 'only' using it for all my baking and microwave needs. A good microwave/convection/grill combo is faster and far more even heating than a separate microwave or (short of 20 lb. turkeys) your stove's oven. The cheap ones sold by Walmart for around $200 are worthless, the over the stove ones starting around $450 very good.
Mine is a B/S/H, but the innards are Samsung.
My 2 cents.
I just sold my Kenmore MicroWave. I just wasn't using it anymore. I just put my leftovers in a skillet with a touch of water, cover, low heat and by the time I check e-mail,or fold a load of laundry it's hot. I just keep reading more and more about all types of radiation: Microwaves,Cell Phones,Wireless Internet etc., and I figured I'll just have more room in the kitchen without it.
Panthera:
Would you have a link to ARC you mentioned in your post above?
After researching Maytag Microwaves, we decided to go with a nice GE unit. The GE reviews seemed slightly better than the Maytag units. Quieter, better rangetop lighting, etc.
ARC
May not exist in your neck of the woods. It is a licensed charity which sells used and donated goods. Depending on your location, it can be very much cashmere and silk or polyester and trailer-house furniture. I never realised they were limited to Colorado until just now!
Still, lots of places have those glass inserts and plates. Goodwill in Denver has billions, as does St. Vincent de Paul in Cheyenne.
Aren't there wind up turntables at Walmart for Microwaves? Wouldn't that do it?
When our Kenmore Meal-In-One Microwave from 1980 died a few years back. We were astounded that you could buy a microwave for $40 at K-Sears. In talking to the guy at Sears-Mart he said think of it like this.
Years ago you paid $500 for a microwave and it lasted 20 years or more. Today you pay $40 and it last a year to five years. You are still paying the same, it's just planned replacements.
In other words, Microwaves, Washers, Dryers are not longer white goods, but commodities.
They are also no longer a full week (or two week's) pay.
Most don't want to pay the dollars necessary for the quality of Maytag or KithcneAid anymore.
A woman I know had a Maytag highlander from the early 60's well into the late 90's. Price turned her off and she bought a SEARS washer? HUH?
