Designgeek
- Joined
- Dec 12, 2004
- Messages
- 865
Seems to me that the actual capacity of washers tends to be lower than their rated capacity. I have never seen a machine, top or front loader, including commercial-grade machines at laundromats, that can effectively deal with more than about 50 - 70% of its rated capacity. Putting in 100% of rated weight only tends to overload the machine at the expense of cleaning effectiveness. In a top loader, overloads could also cause excessive mechanical wear.
So the question is, how many of us have actually weighed the loads going in? And what results are we getting?
What I'm looking for is: Machine make & model number, type (vertical agitator, vertical impeller/pulsator, horizontal drum, inclined-axis drum, other), diameter of drum, depth of drum (specify inches or centimeters) manufacturer's rated maximum capacity (specify lbs. or kg.), and actual maximum capacity in your own experience (please use weighed loads, don't estimate based on the "apparent" weight of a given volume; also specify if loads contain "difficult" items such as blue jeans or large articles such as sheets).
When getting weights, be sure to subtract out the tare (empty) weight of your laundry basket or equivalent container. 5-gallon buckets on shipping scales are useful for this purpose. If the washing container is an odd shape, e.g. the Hoovers which are rectangular with the lower right corner cut to an angle, try to get measurements if possible.
I have a hypothesis that there will turn out to be a consistent numerical relationship between the dimensions of the drum and the actual load capacity. (I know that agitators vary in absolute volume or displacement, but I think this factor will average-out.)
Seems like y'all could gather a huge amount of data quickly, since most people here have more than one washer and some have sizeable collections. This might also be an interesting bit of research to do at the yearly convention. And it could have significant value to consumers for whom usable capacity is a factor in their buying decisions.
