Addendum to Presto Cookers and Instant Pot...
Ain’t she petty! Lol. Those beans were cooked perfectly in that thing. Will be trying potatoes and mashing/whipping them very soon.
Really looking forward to being able to have mashed potatoes in 20 mins as opposed to over an hour.
Toploader55, I usually cook the potatoes in chicken broth, so I would imagine the cup of broth replacing the water will be sufficient? What do you think? The green beans I prepared in the pressure cooker could maybe used a bit less time ( I think I cooked them for four minutes).
My hunch is the potatoes will have more body with much of the starch being retained as you mention.
I am going to try a pot roast in the cooker this weekend and use the regular ingredients I normally use. Will be interesting to go from a slow cooker to a pressure cooker pot roast.
I think that amount of stock should be good.
Brocolli can be hard to figure out. Sometimes if it's really thick and tight packed buds, the buds can be mush and the stems "al Dente".
The Shocking of Vegetables is important with Pressure cooking as well as conventional. But unless you're serving them right away, it's good to cool them with cold water. Otherwise they keep cooking and will be mushy.
Pot Roast does well with the "let the pressure drop to it's own accord" to quote the Presto cook Book
https://www.gopresto.com/recipes/ppc/howtouse.php
https://www.gopresto.com/recipes/pressurecooking/index.php?PHPSESSID=6d4888
In my book, Russet or Idaho potatoes should be baked or fried (or even nuked).
Boiling/steaming is for red/white potatoes, which are waxier and don't fall apart when done in water.
I have all sorts of pressure cookers but more often than not I'll cook red/white potatoes on the stove top. Takes five minutes to boil, and another 15 to cook. 20 min tops. The pressure cookers can take that long, or longer, to get to pressure, cook the potatoes, and then do a natural release. Plus on the stovetop I can poke them with a fork to determine if they are done.
I use a pressure cooker for stuff like brown rice, artichokes, etc. Stuff that takes more than 40 minutes on the stovetop. Even then, each time it's a bit of a science experiment.
"In my book, Russet or Idaho potatoes should be baked or fried".
OMDDBJ !!! Absolutely. But why I like Idaho for mashing is because you have total control over the consistency. I do mash Yukon Golds, Red Bliss, Maine New Potaoes and their flavor is wonderful. Almost Buttery like.
But for Straight up mash that has stand up to a lot of Gravy or Jus, You can adjust the texture better. Add Chicken Stock or Milk, or Sour Cream or all of that as I like a "stiffer" mash when dousing it in Pot Roast Gravy, Chicken Gravy, or just plain Meat Juice.
That's just my thang.
Potatoes, like nearly everything but meat
Should be shock cooled.
This is one of the few genuine advantages of non-electric/electronic pressure pans: They can be cooled down by a stream of water across the lid or in a basin of water.
Except for meat and canning (of some things) everything cooked in the pressure pan should be shock cooled.
I love Nevada Russets.  They're so much smoother and creamier than those from Idaho.  They're not easy to find, though.
Raley's (AKA Bel-Air and Nob Hill) markets out here have locations in Nevada and have been known to stock Nevada Russets in all of their stores.  I don't know if they still do; none of their stores are conveniently located to me anymore.  If not, they might still be available through special order.
Mike, based on my own recent experience, go easy on the liquid for the pot roast.  It will generate some of its own.  I did my first one in a PC not that long ago and should have used less liquid.  Also, err on the side of less cooking time.  You just want the meat to be tender and not to lose all of its structural integrity, as in pulled pot roast.
Reducing liquid and time
rp2813, thanks for the advice. My slow cooker recipe is the one I planned to use in the pressure cooker and that normally requires about two cups of liquid. I will definitely reduce the liquid and also will monitor the time. Tks!
http://reduceing liquids
Thank you Bob
Bob, thanks I had found a similar recipe using a PC and upon rp2813’s suggestion, I am going to reduce the liquid a bit. The one thing I miss about having a slow cooker is the wonderful aroma that permeates the entire house when a slow cooker is cooking.
I've done a large (pulled) pork shoulder in a PC, which takes a couple of hours.  The aroma was present as if I had been roasting it in the oven.    People remarked about it as they entered the kitchen.  You may not smell a PC pot roast cooking for as long a period as you would with a slow cooker, but you'll get an abbreviated version.
Cooking aroma...
Wonderful cooking aroma permeating a home is nice, but bear in mind that the more aroma in the air, the less flavor that may be left in what is being cooked.
Of course, a little scent doesn't take much substance, so usually it's not a concern, unless stuff is overcooked, and then there are other issues.
Ever encountered the "its smells so good, but tastes so bland" phenomenon?
I'm careful about what I cook during the winter because there's no exhaust fan in our kitchen.  Just the other day I fried bacon out on the patio for a quiche.   Otherwise, this house would still smell like bacon.  Not the worst smell in the world, but I don't need to be constantly reminded of what I ate last week.  Absolutely no fish gets prepared in the kitchen, usually even during the warm months.
Ralph,
we don’t have an exhaust to the outside either. But I have found a way to cook bacon with almost no smell at all.
I bake it in the oven at 400 F, preheated, on baking sheets, 6 slices to a pan. I spray the pans first with Pam (you’d think bacon wouldn’t stick, but it does), lay the slices evenly, it takes two pans for a pound of bacon. Put the pans in the preheated oven for 10 mins., then rotate pans, top to bottom and turn each pan around too, to facilitate even browning. Set timer for another 5 mins and check, usually the bottom pan gets done first. If not done, give it about 3-5 mins more.
Bacon done this way comes out perfectly every time, no splattered grease to clean up, no turning and tending and burns from splattering grease, almost no smell, if any at all and the bacon strips stay perfectly flat and straight. I make BLT’s about once a month and this makes it a pleasure, and the sandwiches are nicer too because the bacon isn’t curled.
Give it a try, I promise you’ll never cook bacon on the stove again.
Also, to help alleviate other cooking odors I keep a small, shallow dish of white vinegar on the counter and we also have a medium sized air filter that I run when I cook anything that will create odors. I use a splatter shield on top of the frying pan, this not only keeps the area cleaner, it also seems to keep the odors down too.
I sure wish that the builder had vented the hood to the exterior, but with these work arounds it isn’t too bad, odor wise.
Eddie
Oh yeah Eddie, I remember when I was a kid, a friend of mine cooked bacon in the oven.  I think he put it on a shallow baking sheet, and possibly on a rack.  I was impressed with the way the strips stayed flat and they didn't need the paper towel treatment.
We hardly ever use bacon in this household, but I found a marked down package of thick apple wood smoked at Safeway so wanted to use it up.   I'll keep the oven in mind for next time.
Michael-- My mom had that pressure cooker when I was a kid. Oddly, she used it like a regular saucepan; never as a pressure cooker. Don't recall ever seeing the rubber seal or the pressure regulator thingy.
Eddie (toploader55): What does OMDDBJ mean?
Eddie (ea56): Right there with you on cooking bacon in the oven. Less mess, splatter and smell. I use a foil-lined rimmed baking sheet. No cleanup.
