Adding a water level (load size) selector switch to a new commercial Speed Queen?
lukes
Active member
Mar 27, 2018
29
Charlotte, NC
I lost my chance to get a pre-2018 speed queen, I haven't seen a used pre-2018 unit come up in my area, and I need a new washer. I was thinking about the possibility of getting a new Speed Queen homestyle commercial (LWN432SP115TW01) unit which still has a transmission and adding a water level selector switch. The 2017 commercial unit (LWN432SP113TW04) shares the same parts manual as the 2018 unit (LWN432SP115TW01) and it appears they just changed the pressure switch to a fixed pressure sensor. I want to make sure I am not missing something obvious or otherwise. Is it correct in thinking I could replace the pressure sensor in the 2018 unit with a pressure switch from the 2017 unit? I know I would have to drill a hole in the front panel and buy a knob etc.
Speed Queen commercial home style parts manual: http://docs.alliancelaundry.com/tech_pdf/partsservice/203430.pdf
Adding An Adjustable Water Level Control To A SQ Commercial
Top Load Washer, Hi Luke, yes what you want to do is easy, I would not contact SQ about the proposed change of WL switches. If any thing talk to the commercial distributor  you are buying the machine from, but I think you have it figured out already.
As long as he does not mention what he is going to do, I see no issue in contacting SQ. There was a member on here who was curious about the cycle times and Speed Queen sent him a tech only service manual.
True, but I'm not sure if the OP has purchased machine yet. Knowing ahead of time makes things easier. I used to do it all the time when Service Matters was open to the public, made purchasing machines ahead of time for mods a no brainier.
All really good points, I have not bought a commercial unit yet. I am still trying to weigh my options and am hoping a used speed queen comes up in the next few months before I get rid of the Samsung front loader that came with my house. Also I am not exactly sure where to buy a commercial unit except from a online store.
chetlaham,
Will that control panel plug right up to the existing connectors on a new unit? The control panel also does not have extra rinse, is that just a switch that is added or does the timer have to support it?
Plugging in
Honestly, I am not 100% sure if it will plug right in as I have never been in a commercial unit (yet), however the wiring is simple and splicing it to the new harness will not be difficult or complex if you only have basic wiring experience.
Regarding extra rinse the timer has to have that function built into it.
After some digging through the parts manual it seems you can also convert the 2018-2019 electronic homestyle commercial unit to the 2017 and before electronic unit with a new control panel and pressure switch. This change seems very tempting as I always wanted the AWNE92SP113TW01
Parts to convert manual timer commercial unit LWN432SP115TW01 (2018-2019 no water level switch) to LWN432SP113TW04 (pre 2018, has water level switch)
202937 - Pressure switch
203323 - Knob
203673W - Front panel, if you do not want to drill a hole in existing panel
Parts to convert elecontrinic homestyle commercial unit LWNE22SP115TW01 (2018-2019) to residential AWNE92SP113TW01 (pre 2018)
202769P - AWNE92SP113TW01 control panel with overlay
203843 ??OR?? 202470 - Pressure sensor
- The pressure sensor in the parts manual changed in the 203417 rev 9 parts manual, the rev 8 and before lists the pressure switch part number as 202470
- Parts Manual 203417R8: https://s3.amazonaws.com/productuploader-uploads/staging/2/Document/464758_1531749895_203417.pdf
- Parts Manual 203417R9: http://docs.alliancelaundry.com/tech_pdf/PartsService/203417.pdf
Photos below: Pressure switch to add water level select to 2018-2019 manual homestyle and front panel to convert 2018=2019 electronic homestyle to residential 2017 electronic units
load selector adder
You are correct in the part numbers for this conversion.
203323 - Knob
I just did it and it works great.
The wiring harness is different. New PS has only three wire connections. The SP115TW01 has an overfull switch as part of the fixed pressure switch that variable switch of the SP113TW04 does not. (Just spliced those two wires together.) Had to cut the other wires and put spade connectors on as the original plug is much larger and does not mate up.
I found a last-in-stock floor model LWN432SP115TW01 at one of the local dealers. Tried for two weeks to be OK with no load size selector, but it was driving me crazy. Now it's the machine I've always wanted.
Speed Queen Market
There's going to be a market for 2017 SQ's and other old favorites. Think someone could make money reselling fixed up SQ's and other machines that really clean.
LWN432 - Where to Buy?
After some digging through the parts manual it seems you can also convert the 2018-2019 electronic homestyle commercial unit to the 2017 and before electronic unit with a new control panel and pressure switch. So where can one buy this? Also, where can one buy the mechanical LWN 432, which is what I would prefer. Isn't it still made? My local dealer said they cannot get them. The only place online is applianceconnections.com that has several negative reviews. I keep seeing this recommended, but they are almost impossible to find.
Thanks,
goosey,
Thanks for the pics!
PinkPower4,
I purchased my AWNE92SP113TW01 electronic unit from Appliance Connection but they also sell the manual dial version. I had no issues with the order, others on the board have purchased from there as well. I have not seen anyone post issues with the company.
To convert the electronic model it turns out you don't need the pressure switch, you only the control panel and there is no wiring modifications needed.
Thank you. Do you think the mechanical and electronic will continue to be available? Or have they been discontinued and they are selling out the last of the stock?
PinkPower4,
I do not know how long they will be available but as of know it seems the commercial units with transmissions are still in production in electronic and mechanical styles.
combo52,
The new residential units had a complete redesign with the removal of the transmission starting in 2018 as you were referring to but the 2018-2019 electronic and mechanical commercial units still have a transmission and are pretty much the old 2017 residential units
SQ Home Style Mechanical Top Load Washer LWN432SP115TW01
New member here and would appreciate insight/advice on this model. I'm attaching spec sheet for this model that shows water/load level control knob. Two women at SQ are telling me that this model has NO water level control knob, hence my confusion. I'm seeing pics/videos on line of this model with and without the water level control. I'm assuming they made different models of this LWN model, or maybe the one's with the water level control were older models? Are any of you knowledgeable about this model? Thank you in advance for you time/help.
If it's easier to correspond to help me, my email is: [email protected]
sorry, wont let me load pdf or word doc of spec sheet.
https://www.google.com/url?sa=i&rct...&psig=AOvVaw0LWf1vfu2a4c2TicCBUgQS&ust=156859
I am excited to find this information -- I was resigned to buying the "Classic Clean" TC5 home model despite losing the load size control, but am now looking at converting the current commercial mechanical (i.e. LWN432SP115TW01) as described by Goosey.
Goosey -- have you had any issues with your conversion now that it's been over a year?
Also, what is the function of the "overfull switch" that you disabled, and is there any downside to disabling it?
Thanks for your help.
Best washer after slight mod
Hello All, I wanted to confirm the solution outlined above to add the water level is valid! I ordered all parts listed above (3) and used Goosey's pictures, following his wiring to a T (Fairly simple) and all is functioning as it should.
One tip when cutting out the old switch out, leave no more than 3/4 inch of the wires off the original switch (in case you need to rollback and re-wire it in). I left about an inch of wire off the original switch. When I added connectors and plugged them into the new switch, the wires were quite tense because I had left too much wire off the original switch.. Hope that makes sense!
So glad I found this forum. Pictures to come if anyone is interested..
Hello there everyone,
I just wanted to give everyone a slight update on this thread. I purchased a LWN432SP115TW01 a few months ago and I came across this thread when i was on the hunt for how to add a water level switch. I read through the whole thread and decided to go through with the mod/addition suggested by LukeS. However, after reading through and studying the parts manual and noting the differences between the two models, i did end up getting a few more parts so that i didn't have to cut and splice wires or bypass anything like in the previous posts. I am, in no means, a repair technician. I am pretty handy and i just wanted to make sure i did this the right way and maybe my OCD got the best of me. If someone here would like to correct me or anything i might have missed (or misunderstood), please do!
Here is a list of the parts i used to get it to be a true(er) LWN432SP113TW04:
202937 - Pressure switch (the one the knob attaches to that selects load size)
203323 - Knob (attaches to above switch through the front panel)
203673W - Front panel (if you do not want to drill a hole in existing panel)
203428 - Wiring Harness (so that you don't have to cut or splice wires together)
B12548401 - Pressure switch (yes, another one) - This is what the two blue wires are supposed to attach to
203511 - 8" PVC Tubing
203464 - Barbed Tee
Don't get me wrong here. This is going to cost an extra 70-80 bucks going my route. If everything for everyone who posted above is working fine, feel free to go with the short list of parts and save money, if that's what you want. I just had an aversion to cutting wires and then splicing the two blue together; It made me wonder what they went to. And hell, i still don't understand why there are 2 pressure switches and what the 2nd one is actually for. All i know is that the LWN432SP113TW04 has 2 of them and if you don't splice the blue wires together or plug it into switch #2, then the Heavy Duty/Perm Press portion of the timer will not work.
A benefit to going this route is that you can revert all of it and go back to stock if one of these pressure switches goes out at some point. That way you can still wash clothes while you're waiting for the new part to arrive. Simply swap the harness and put the old pressure switch and front panel back in.
Anyways, a few notes here if anyone is wanting to go the route i went.
Wiring Harness - The 113TW04 Harness exactly the same as the 115TW01 Harness, except the 113TW04 has separate plugs for each of the pressure switches instead of one long plug for the single pressure switch. Everything else is the same and plug and play into the 115TW01.
Pressure switch #2 - as i stated above, i don't really have a clue what it does or how significant it is. In the parts manual, it's labeled as Pressure Switch, that's it. On the parts website (i used PWS Laundry), it's labeled as SWITCH, PRESSURE WTR 1 LEVEL (300/255). This part fits directly into the spot where the 115TW01 Original pressure switch was. Clip is included to pop right in. No adjusting or modding needed.
PVC Tubing and Barbed Tee - I knew i didnt NEED to buy the OEM tubing and Tee, but they were so cheap so why the hell not? The 8" PVC tubing is attached to Pressure Switch # 2. The other end of the 8" PVC tubing goes into the right side of the barbed tee. I then cut some of the excess tubing (maybe 5 inches) from the original washer tubing to connect the bottom of the tee to Pressure Switch #1. Whats left of the original washer tubing then connects to the left side of the tee.
I am a knuckle head and didn't take photos of how it turned out, but i will gladly go take the panel off and do so if someone here isn't understanding what i did or is just curious to see it. Over all, it was a super easy swap. All you need is a flat head screwdriver and a standard (not metric) socket set. The exterior screws are 1/4" socket and the ground screws are 1 or 2 sizes bigger (can't remember, sorry).
Take care everyone! Please feel free to ask me any questions or point out any mistakes i may have made. Again, i am not a technician, just pretty handy and patient enough to go through the parts manual.
Tiny
Tiny,
How did you know how to set the T in the tubing of Pressure Switch #1?
It makes sense to me to do it that way but I couldn't see it depicted in the parts manual.
Is your washer working alright?
I think spending an extra 70-80 dollars on something called an 'overflow' switch is definitely worth it.
Thanks,
jcrocket
Jrocket,
I did what made sense to me. I knew that the original tube push/pulled to each of the sensors. So I basically just assumed it went that way. I tried searching for wiring images of the 113TW04, but couldn't find anything. Before I screwed the panel back in, I did a test run of the way I set it up and it all worked flawlessly. I will take some photos this week and upload it.
Tiny
Did the mod per TinyTee's post above, and it works! Thanks, TinyTee!
One question, though, for anyone that's done this mod:
Is the load size selector knob supposed to "click" into each setting?
Mine cab stop at any location between "Mini" and "Reset", instead of being a hard click like the temperature knob.
Is there a way to fix this?
