much more conservative approach to ground-fault protection
It indeed is because of the TT system, each building has its own earth pole and the utility company only supplies 4 cables for 3-phase and 2 cables for single phase users. It offers improved resilience over disturbs on the line but also opens a path where ground has low resistance so interrupters have to be very sensitive. Neutral is ALWAYS separated from the ground/earth wire, this offers vastly increased protection in case of broken neutral which can be a common issue in other countries.
Standard is 230V phase to neutral at 50Hz like elsewhere in Europe, with powers of up to 10 kW single phase and three phase (400V phase to phase, 230V p-to-n) over that, of course one can request even a 1,5kW contract in threephase (as an example in country grounds where only a water pump can be used!)
The most common residential contract is 3 kW at 230V monophase. 6 and 10 kW contracts are sought after those wanting induction cooking or heat pump heating but they are charged at a premium rate to incentive low consumption. (Electricity here is the most expensive of all the OCSE nations!)
The only domestic appliances using threephase current are induction cookers and centralized air-conditioners but both can be had to run on single phase albeit requiring much thicker wiring and in the case of A/C at a little lower efficiency.
A single "normal" socket circuit supplies 16A and is protected with a 30mA RCD and has overcurrent and shortcircuit protection (thermal and magnetic protection), if supplying a "delicate" appliance like a freezer or fridge the switch can be of the self-reactivating type to prevent energy loss in case of accidental tripping.
For increased safety bathrooms are generally protected with 10mA RCD and supplemental electronic protected wall outlets are not uncommon at all (such in case the bath is on a 30mA protected circuit one adds a 10mA additional protection).
All the light switches and sockets are modular so one can assemble what he needs in predefined forms in a mix-and-match system, something I've yet to see elsewhere like in France or the UK!
The residential systems are defined under the CEI64-8 norm, the degree of standardization is such that they even mandate the number of sockets and circuits for each room/house size, destination and place, besides the minimum requirements, so on that aspect I'm most satisfied!
Fault and shock protection is mandatory since the 60s, can't remember the law number but is quite old and was renovated quite a few times.
As an example I have never seen a fused circuit in all my life even in old (60s) installations as MT and MTD (magnetic+thermal+differential protection) was the norm.
Only industrial/commercial users had fuses on large current circuits but even in these applications MTD interrupters are the norm now.
en.wikipedia.org
