Advice/guidance sought - troubleshooting 1956 Canadian Westinghouse refrigerator
turquoisedude
Aug 8, 2007
10,589
My month of March was kind of a disaster all around.  I took off on March 4th for a short vacation break with my Hubby to Mexico.  We needed a Covid test to get back into Canada then and well, guess who failed... I was stranded another 10 days, isolating until I could finally return to Canada.
Naturally, while I was away I got a disturbing email from Hubby - "that old fridge of yours isn't working right".  After a frantic series of messages, I narrowed it down to the 56 Canadian Westinghouse "Frost Free" I use as an overflow fridge in St-Liboire.  The problem turned out to be that it was freezing everything.  I instructed Chris to adjust the temperature to a warmer setting but that made no difference.  I can't confirm if the refrigerator was running continuously but Hubby did manage to get it to shut off.  And subsequently not restart.  I finally took a half-assed look at it today, thinking the cold control was shot.  However, when I extracted the control unit, it looked to be very much more complicated than I am experienced with.  The 4 wires coming out of the control are throwing me.  I suspect there's a relay tucked in there somehow and and I was not sure if there was a way to short the cold control switch to see if the compressor would still start.
It's a long shot but does anyone out there have some service/diagnostic information on one of these 'pushbutton defrost' Westys?
The Canadian model/style numbers may be very different from similar US models.   Mine is a model PK-125 for whatever that's worth.
I'm not sure how the pushbutton defrost mechanism works, however I do have info on the thermostat control. It contains the start-relay and the thermostat in one module. Is the pushbutton defrost part of the same thermostat control? In your picture it looks to be a separate switch.
I will share a generic Westinghouse wiring diagram shortly which shows how the thermostat and start relay interact with the compressor, but it won't have the defrost circuit on it.
Thanks for jumping in!
Hi Dave, I was hoping you'd see this post... LOL
The pushbutton defrost is a separate unit - it's in fact a countdown timer that activates a circuit to an electric heating unit in the freezer section (Not sure exactly how that is placed, though).
I was afraid that there was a relay in that control - I had an older Canadian Westy (it was a model LH-8 I think) that had a similar setup and which also died due to a relay failure.
I'm looking forward to seeing the generic wiring diagram - thank you very much!
I edited the above post to include the diagram.
If worst comes to worst - you can use an aftermarket thermostat; and also an external aftermarket start relay, such as a Supco RO81. The aftermarket start device, and aftermarket thermostat together will take the place of the Westinghouse control.
Hey Paul - Hope you can get this working!
I'm not sure though that it has a heating element in the freezer - I have an old Westinghouse with the push button defrost that looks similar to yours and mine is a hot gas defrost system. But maybe mine is a bit different.
Anyways - good luck! Your persistence seems to always pay off.
