Alma Laden rebadged as Quellomat
yes
this machine is not automatic. You have to open the stopcock and babysit the machine. You'll stare at the small window under the door until the proper water level shows up and reminds you to shut the stopcock.
Then you switch on the motor and the heater, and check the thermometer now and then. When the proper temp is achieved you have to switch off the heater. Then after 20 minutes you have to engage the drain pump.
Repeat without heater and just for some minutes, also you can spin in between, for 3/4/5 times to rinse.
To cut a long story short, the very only automatic feature this machine had is the reverse tumbling
