An easy (but good) stew recipe needed.
autowasherfreak
Jul 28, 2008
3,637
I'm in the mood for homemade beef stew. I have stew meat, potatoes, carrots, and peas. I just don't know what spices to use, and what is the best way to thicken it cornstarch or four.
It's easy, but takes time... Recipe is based on about 2 pounds of stewing beef (cubed).
- Combine on a plate about a 1/2 cup of flour, 1/2 teaspoon thyme, 1/2 teaspoon majoram, pepper and salt to taste.
- Heat about 1/4 cup oil in a heavy cooking pot slowly. Dredge the beef in the flour mixture and slowly brown a few cubes at a time in the oil. Remove and repeat browning until all the meat is used up.
- Drain off any excess oil and return the beef to the pan. Add 1/3 cup of water and the veggies, cut up as you wish. Cover, bring the water to a boil over medium heat, then reduce the heat to simmer. Add a Bay leaf and a couple of cloves to the pot. Cover and cook slowly, checking from time to time and stiring for about 2 hours or until the beef is tender.
This should result in a tender, flavourful stew with a nice medium-thick gravy.
Enjoy!
What I do is brown the meat first then put everything in a crockpot and use either tonic or seltzer water, not plain water. Then when it is done, thicken it with Gold Medal Wondra by taking a separate bowl with some broth from the stew and slowly wisking in the Wondra until it makes a thicker, non lumpy mixture, then pouring it slowly into the crockpot set on high until it thickens by constantly stirring easy. As far as seasonings, I use seasoned salt, fresh pepper, garlic powder and McCormicks Roasted Garlic and Herb seasoning. But you can always season to your preference. If I dont have Wondra, I prefer cornstarch for the thickner over flour but both will work. The idea is not to have any lumps in the gravy.
My mother could make the best soups and stews, and she never used a recipe. I wish she would have written some of her "in my head" recipes down for me.
I'm LAZY ,but this is sooooo good (to me anyway)
I used stew beef - Frozen stew vegetables (which are cut bigger) along with frozen mixed vegetables and MSG FREE beef stew seasoning into a crock pot and then filtered water. Sometimes I will also add a package of brown gravy mix because it adds flavor and thickens it somewhat, but brown gravy mix has MSG......MSG is BAD BAD BAD!
I know I could use fresh veggies and I have before, but I can't tell the difference.
I've also tried browning the beef with flour and oil, but could not tell the difference in the end so I stopped doing that.
I wing it with slight variations each and every time... Rosemary is one spice that I always incorporate.
As for thickening agents.. Potato starch or corn starch. I prefer the potato starch though it can be harder to find
Coca Cola Stew
Hey Louis, I've tried a similar Coke stew recipe and it is good!  Another Coca Cola recipe I like is for barbecued chicken. Place chicken breasts ( on the bone with skin) in a baking dish and cover with 1 can Coke and 1 Cup ketchup which have been combined.  Cover with foil and bake at 400 degrees for 45 minutes then turn the oven off and let it sit for about 20 to 30 minutes.  I've also used Diet Pepsi and it was equally good.  So good and so tender.
I dredge my stewing meat in well seasoned flour(salt, pepper, garlic powder) then brown in cooking grease(usually bacon drippings) then I add water, beef soup base, a whole onion, a good amount of Sweet Hungarian Paprika, a tablespoon or so of Gravy Master, and chunks of carrots(I dont like the flavor of the baby ones), potatoes and occasionally a few peas. I simmer for 2 or 3 hours and then thicken.
To thicken I use a few tablespoons of Wondra or Cream Corn Starch and wisk well into about 1/3 cup of tap water until smooth and then add to the stew and keep stirring until it boils and thickens.
My preference for beef stew is a rather thick and dark brown gravy.
I always serve beef stew over a bed of buttered egg noodles
Oh when I make stew it fills an 8 quart pot
This one is very easy and tastes great. It's cooked in the oven so there's no tending to a pot on the burners.
DAMN GOOD OVEN BEEF STEW
1-2/3 cups tomato juice
2 teaspoons sugar
3 tablespoon Minute tapioca
3 pounds lean beef stew meat
3 bay leaves
6 carrots, cut into chunks
4 stalks celery, cut into chunks
1 large onion, chopped
4 large russet potatoes, cut into chunks
2 teaspoons salt
1/2 teaspoon ground black pepper
1. Adjust oven rack to middle position. Preheat oven to 250 degrees. Spray a 4-quart casserole with nonstick cooking spray.
2. In a bowl, whisk together tomato juice, sugar, and tapioca.
3. Layer remaining ingredients in order listed above. Sprinkle salt and pepper evenly over the top. Whisk tomato juice mixture again, then pour evenly over meat and vegetables.
4. Cover casserole dish. Bake for 4-1/2 hours or until meat and vegetables are tender. Remove bay leaves before serving.
Brasato.....stew...if you have time...
Brasato is typical of my area piemonte (Alessandria,  Valenza, Casale monferrato ecc...), it is not difficult at all, and rich in gravy.
This is how I make it:
<span id="result_box" lang="en"><span class="hps">    1 kilo of</span> <span class="hps">meat</span>
     <span class="hps">1 bottle of</span> <span class="hps">Barolo (or no sweet Red wine in lack of Barolo)</span>
     half <span class="hps">glass of</span> <span class="hps">Cognac</span>
     <span class="hps">2 onions</span>
     <span class="hps">2 carrots</span>
     <span class="hps">celery stalk</span>
     <span class="hps">2 cloves</span> <span class="hps">of garlic</span>
     3 or 4 <span class="hps">cloves</span>
      <span class="hps">a few juniper berries (otional)</span>
     <span class="hps">a few peppercorns</span>
     <span class="hps">a</span> <span class="hps">bunch of herbs</span><span>:</span> <span class="hps">bay leaf,</span> <span class="hps">sage</span><span>, rosemary, thyme</span>
     <span class="hps">Extra</span> <span class="hps">virgin olive oil</span>
     <span class="hps">butter</span>
     <span class="hps">A pinch of</span> <span class="hps">salt</span>
     <span class="hps">Salt</span> <span class="hps">to taste</span>
<span class="hps">1)</span> <span class="hps">P</span><span class="hps">ut the meat</span> <span class="hps">in</span> a bowl enough big <span class="hps">( for a piece of</span> <span class="hps">at least 1 kilo</span><span class="hps">).</span>
<span class="hps">2) Cut</span> <span class="hps">in</span> <span class="hps">large</span> pieces<span class="hps"> the</span> <span class="hps">onions</span><span>, carrots</span> <span class="hps">and celery and</span> <span class="hps">sprinkle</span> <span class="hps">on the meat</span>
<span class="hps">3) Add</span> <span class="hps">the herbs,</span> <span class="hps">cloves</span><span>, cinnamon,</span> <span class="hps">juniper berries</span><span>,</span> <span class="hps">peppercorns</span><span>, a pinch of</span> <span class="hps">salt</span>
<span class="hps">4)</span> <span class="hps">Finally</span> <span class="hps">pour in the </span><span class="hps"> wine</span>.
<span class="hps">5)</span> <span class="hps">Marinate the meat</span> <span class="hps">in the wine</span> <span class="hps">for at least</span> <span class="hps">half a day</span><span>, placing the</span> <span class="hps">container in</span> <span class="hps">a cool place</span> <span class="hps">or</span> <span class="hps">in the refrigerator.</span>
<span class="hps">6)</span> <span class="hps">Then</span> <span class="hps">drain</span> <span class="hps">the vegetables</span><span>, cut them</span> <span class="hps">smaller and</span> <span class="hps">"brown" them</span> <span class="hps">in a large pan</span> <span class="hps">with extra</span> <span class="hps">virgin olive oil</span><span>, butter and herbs.</span>
<span class="hps">7)</span> <span class="hps">Drain</span> <span class="hps">the meat, dry it</span> <span class="hps">and fry</span>/brown  <span class="hps">over high heat</span> <span class="hps">in the</span> <span class="hps">chopped vegetables,</span> <span class="hps">flaming then </span><span class="hps">with</span> <span class="hps">Cognac</span>.
<span class="hps">8)</span> <span class="hps">Finally, add</span> <span class="hps">the sauce</span> <span class="hps">from the marinade,</span> <span class="hps">cover the pan</span> <span class="hps">with</span> <span class="hps"> lid</span> <span class="hps">and cook on</span> <span class="hps">low heat</span> <span class="hps">for</span> <span class="hps">a couple of hours.</span></span>
<span lang="en"><span class="hps">9) Cut in slices, add slices in the gravy and let simmer (low heat) for 20 minutes.</span></span>
<span lang="en"><span class="hps">Done!
You can serve it with Polenta, usually is the main thing it is served with, but even boiled potatoes or mashed potatoes.
P.S</span></span>
<span lang="en"><span class="hps">If you want to thicken the gravy you can boil it with a tbsp of corn starch or potato starch before slices are added into (corn starch is best).
</span></span>
Forgot to mention
P.S
Meat cuts you can use are:
rump roast or top round are preferred.
Also, you can do that with ground beef too!
With ground meat it  turns also as a wonderful pasta sauce also, it is typical to have  agnolotti  with Brasato  in my area as well(  agnolotti are meat filled pasta) not sure if you can find  ready agnolotti   in your area, I just managed to find them at "Market Basket" supoermarket  in New Hampshire in the frozen aisle.
I use stew beef (chuck) because it's very flavorful and gets tender as it sits a-stewin'! This recipe is for use with a slow cooker. Variation for stove-top or oven follows. Like Pete, I wing it each time, but there are certain constants.
Keep in mind that you could make this very easy and just take all these ingredients and toss them in the slow cooker and thicken when done. However, the browning and deglazing does add a good layer of flavor to the finished stew.
You asked about flour vs. cornstarch. For anything needing a gravy, per se, I use flour. If it's a liquid in a pie, fruit crumble, or something else that should be more translucent, I use cornstarch. I guess that with some exceptions, it's flour for savory and cornstarch for sweet.
I brown a thick chuck steak or thin roast on the grill to carmelize the outside. It's not required, but I like to think it adds to the flavor. If you don't grill it you can use it raw or brown it in the pan you use for the onions before you do the onions.
While that's going, cut two medium onions into a large dice and brown with olive oil in a pan, stovetop. If desired, trim and quarter about 8oz baby bella mushrooms and pop them in with the onions. Cook on medium-high until the onions are medium brown. Deglaze with 1c red wine (always use a wine you like to drink, or broth if you don't like to use wine) then add it all to the slow cooker. A little more wine won't hurt!
Trim the fat from the beef, grilled or not, and cut it into 1/2" - 3/4" cubes. Throw it in the cooker.
Cut about 3/4# carrots into medium chunks, about the same size as the beef. Same with about 2 large potatoes. Cut 2 large ribs of celery into half that size. Use more or less of each veggie depending on what you like. Throw it all in.
For seasoning, I use the leaves from a few sprigs of thyme, chop about 1T rosemary leaves, 4-5 cloves of crushed /chopped garlic, a sprinkle of black pepper, a dash of nutmeg, a couple dashes of worcestershire, and a few bay leaves. Remove the bay leaves before thickening the broth later.
At this point, add in whatever other raw veggies you like in your stew but don't fill the slow cooker more than about 2/3. If you want to add some frozen peas or something, add about 1C near the end just to heat them through.
Add low-sodium broth (beef, veg, etc) to bring the level to about 3/4 full. Slow cook on low all day or high 3-4 hours.
To thicken, employ a beurre blanc or flour slurry. For beurre blanc, mash equal parts butter and flour together into a paste and stir it into the bubbling liquid. For a slurry, mix flour and broth (or water) into a thick liquid and whisk it into the broth. Add slowly and allow it to come to a bubble before adding more as it thickens as it heats. I usually use the slurry.
If you do this stovetop, use a heavy-bottomed pot. Brown the cut meat in a little oil and reserve. Brown the onion (and mushrooms if used), then add seasonings and stir for a minute before deglazing and adding everything else but the thickener to the pot. Simmer gently, covered, for 2 hours. Thicken when done.
For the oven, use an oven safe vessel and follow as for stovetop, but put in the oven, covered, for about 4 hours at 300.
I don't add salt for dietary reasons as there's enough in the reduced sodium broth for me. If you want to add some, go for it. Same with any other seasonings you might like. Stew is a great "use it up" meal!
Good luck,
Chuck
beef stew seasonings . . .
The beef stew recipe I use was my mother's. It very easy and uses the same ingredients in the OP, plus a few more. Spices/seasonings are
1 Tbsp catsup
1 or 2 bay leaves
1 tsp. Kitchen Boquet
1 tsp. Worcestershire Sauce
Salt & pepper to taste, added upon serving but can use during cooking.
I often toss in a cut up onion for flavor, as well as some chopped celery.
1 - 2 Tbsp. flour are all I've ever used to thicken it.
I usually make this on the stove top, but used the crock pot last week. No pre-browning of met, just cooked on low for 6 or 7 hours and it was great.
