another GSD2800 sighting
I really like that whole family/genre of GE dishwasher.
Having recently gone back to a GSD1200, I'm a believer. I like that my machine is not electronic, but I had a GSD2200 in 1986, which was GEs cheap alternative to the 2800.
As it has been said on here many times, the top racks in these machines are spectacularly useful. I've never had a performance issue with one of these, except for upside-down Tupperware, which then fill with water. This was a pleasant surprise a few weeks back in the 1200, as I'd gotten used to the low power nothing-ness in my GE Tall-Tub.
I don't know about the electronic longevity in the 2200/2800, but they sure are neat. I'd have a 2200 again just because mine was my first dishwasher ever.
Gordon
Hey Gordon,
Yeah, they are wonderful machines. I can only speak of the 2800's I have had. Never had an electronic issue. My current 2800 is D model so I can only guess that the production date was around 1982 - 84.
The smart board is works fine and the flourescent display is still bright and the warm arm, sensor, drain sensor and detergent cup sensor all work as designed.
Amazing, isn't it, that a 25+ year old machine can still provide capabilities that are on not on modern produced machine.
Some machines give you some of the functions (a very few tell you of blocked wash arm. I don't know of any that tell of unopened detergent cup, water below temperature, blocked drain, slow drain, low water level.
In addition you have a full user display of current operating functions (wash, rinse, dry), energy usage, and countdown timer. Plus a visual alarm as well as audio alarm of malfunctions.
I never had the 2200, but like the 2800, it was a good looking machine, and still had more functions than many of today's dishwashers.
No, I agree, a GE Tall Tub is a let down after having a 2800 or 2200.
GSD 2800 GE DWs
These were pretty advanced machines and I am glad that you have one that is still working Barry, It is sort of like my KA KDSS-20 DW which is still working but shouldn't be if you think about it. I still have one customer that still has a GSD 2800 that works, I just put my last used board in it this year, and replaced the burned wiring harness that supplies power for the motor. One of the best things you can do to extent the life of the board is to get rid of the shaded pole motor that consumes so much power and usually is the cause of burned boards and wring harnesses and replace it with the PSC motor. If you don't want to replace this crude noisy power hog of a motor you can install a relay and a direct power connection to the motor to spare the board.
But overall these DWs were a pretty cool piece of history, they are a little like my early build 1981 Chrysler Imperial that still has fully functional Electronic Fuel Injection. I look under the hood at times and wonder why it still works, but like the GE Electronic DWs I would not go out of my way to get another one.
This is a little off topic...curious on that Imperial. What were the starting instructions in the owners' manual? Just turn the key (as today) or did you have to press the gas (to set choke/throttle/jets/...). I am curious about the early days of fuel injection with the primitive electronic controls.
TYVM.
STARTING EFI EQUIPPED 1981 IMPERIALS
You merrily turn the key no matter what the outside temperature to start, like todays vehicles. I have a book that breaks down and explains the operation of about 15 different fuel injection systems that was published in the early 1980s that you would find interesting.
