Another interesting Top Loader.
This definitely gets clever points, and looks cool too.
The way it works is probably that the impeller under the inner tub pumps water up the sides of the outer tub, which cascades down on the load, and all this in addition to the usual pulsator action & counter-rotating tub.
Capacity of 6 kilos -> approx 12 lbs., but realistically, on a compact machine, you can expect 4 to 8 lbs depending on what's in the load. 4 - 5 lbs if you've got one or more pair of bluejeans in the load, and 7-8 lbs. if it's all underpants & white socks, and 6 lbs for a mixed load that doesn't have more than one pair of blue jeans in it. Or if they can get 12 lbs into a compact machine, someone deserves an engineering award...
Now if only they'd bring back good old rotary knobs instead of those confusing modern touch panels:-)
