Another Kenmore DD washer
stan
Oct 20, 2010
2,084
Napa CA
Hi guys
So 5 years ago a freind got rid of her Kenmore DD and bought 2020 Maytag top loader with matching dryer. She was never too crazy about the new Maytag. Anyway..the Maytag shook itself to death or something last week. (I wasn’t there) and she decided she hated it and wanted rid of it and out of her sight! LOL
After spending what she spent on the Maytag, she didn’t want another new style washer..she asked me to find her something older that I’d have a better chance at fixing if ever needed repair. So I went to a used appliance store and got her this. Came with 90 day warranty.
(Close to the model she should have kept)
It looked to be very clean & in good condition for a 25 year old machine.
I hooked it up, ran an empty load with hot water Borax and a little bleach to kinda sanitize. Machine ran great and was very quiet.
I should have run it with the lid open to see everything instead of just listening to it go through its cycles as I don’t think I heard spray rinses?
Other than that she’s been using and says machine performs flawlessly.
Any reason it wouldn’t do spray rinses at the times I was expecting to hear them?
And any idea as to load capacity?
Stan
    1,004.1 KB
    1 MB
    1.2 MB
My lady Kenmore from 1986 direct drive had only one spray rinse and that was after the deprance and it was one spray Rance no other spray rinses and it was the same on normal permanent press and delicate. In fact delicate had no spray ounces. Permanent press at the cooldown in the spray Rance after that cool down .
In fact the poor rinsing was one of the reasons why I couldn't wait to get rid of it and get a front loader in 2006 and I've had nothing but front loaders ever since. I constantly had the second rinse on the normal cycle always turned on
DD's are very stingy with spray rinses unless you get an Ultra Rinse model. I've also noticed with Whirlpool/Kenmore washers is that the more BOL a washer is, the more stingy it's with rinsing. That even goes for belt drives. I've seen some higher end belt drives do up to 7 spray rinse pulses and others just one after the final spin. Unsure why they didn't engineer a set amount of spray rinses across all models, especially before EPA regulations, like other manufacturers of that time did.
The Kenmore DD I personally use now (pic below is a 1997 and it does a spray rinse during spin after wash..before deep rinse and a spray rinse during spin after deep rinse.
I expected the machine above to do the same as mine at home. I’m not sure of anything since I didn’t run it with lid up and relied on my hearing.
(Most of my hearing went away last year)
Don’t want to think something is wrong with it if it’s normal for that model.
Why do some model have white tub and others have grey?
John were are you? LOL
    1.1 MB
    928.3 KB
Gray basket is a budget/lower model thing. White is an additional porcelain coating/layer.
Is a tech sheet stashed inside the console? It should have a chart of the cycle sequences, which would confirm when spray rinses occur.
I found what should be the correct wiring diagram with cycle chart for model 110.20712990 in the OP. It shows a spray only in the 2nd spin on the Ultra Clean cycle. First (which is the cool down) and 2nd spin on Permanent Press I.
    767.9 KB
It seems to depend on the model. Here's a 1997 Kenmore that does not spray rinse during the first spin, only during the last spin (at 30:49 and 31:30)
Thanks DaDoEs
I didn’t run a PP cycle when I tested it
Can’t blame my hearing then!
I’ll have her run PP and see
Have to say it’s one of the quietest machines I’ve run across
Thank You! :)
Here is cycle sequence and wiring diagram for the 110.27802690 Kenmore Washing Machine pictured in post #5. As with the 110.20712990 Ultra Clean Cycle, there is no spray rinse in the first spin on the Heavy Duty, Permanent Press and Normal cycles. The Permanent Press cycle uses a half tub drain and re-fill as a cool down after the wash period instead of a spray rinse in the first spin. All final spins have a spray rinse consisting of two 15 second bursts of water.
The normal cycle starts on high speed agitation and switches to low speed agitation during the wash period and runs the low speed entirely during the rinse cycle to help reduce garment abrasion while still providing excellent wash results.
Thank You! :)
Thank you
I just listened to the 110.27802690
And thats exactly what it dose on normal cycle. I often set timer at 5 min to avoid the fast agitation that comes with setting the timer for longer
(depending on what’s being washed)
I prefer the 3 speed with separate speed selector. But it a good strong machine.
I started using it a year ago today!
I did a clean out on it before I put anything in it. This is what I found. I’ve seen worse but I wasn’t going to use it for myself until I looked!
    1.3 MB
    3.4 MB
That inner and outer tub is actually what I consider ok. I will clean up in about two dozen loads with enough detergent. I've taken apart washer in scrap piles that were on orders of magnitude worse. Mold, caked on sludge, scum, ect The key keeping your machine grime free is washing in mostly warm water with an occasional hot wash and plenty of good quality detergent dosed well. Washing with these two things in mind will leave the machine looking pristine.
I would not worry about the lack of spray rinse in the first spin. The overwhelming majority of direct drives sold did not spray in the first spin. Spraying in both the first and final spin was usually reserved for marketing. For example "Permanent Press I" which used a spray instead of a half tub drain as a cool down and "Ultra Rinse System" which was quipped as providing better rinse results.
3 Speed provides more care options, however consider that this two speed 3 major cycle model with pre-wash, soak and speckled porcelain basket dominated the Kenmore market in the early to late 90s before the separate speed switch took over in sales. In fact in the very early 2000s Kenmore dropped the two speed two knob model from their full width line-up before re-introducing it a few years latter. People liked it. This model is not a true BOL even though it may come across that way with the re-designed control panel.
Enjoy one of the best washers ever made!
Thanks
I really appreciate you providing
cycle sequences.. very helpful.
I generally wash in warm or hot with warm rinses. (Most of the time)
I don’t use fabric softener as I don’t feel a need.
I have no idea what the washing habits of previous user?
When I cleaned the machine last year, I had to use a plastic putty knife and scrub brush on outer tub and a SOS pad on the outside of the inner tub.
Since I was the one that was going to use it for our laundry .. I wasn’t willing to to wait to run multiple loads to break that free.
Generally when I’ve deep cleaned machines like these..where I have no idea who was using, I’ll run an empty hot load with just a cup or so of straight washing soda and or Borax.
My observations have been..that if theres stuck on gummy liquid detergent, the soda will break a lot of it loose and suds with form.
It just gives me an idea of what I’m going to find when I disassemble to do the deep dive.
(Softens up the grime)
Also..If the machine drains into a laundry sink instead of a stand pipe, it gives me a little more info as to what’s in its innerds .
Who knows... maybe the extra bumps on the timer cam cost them more? Probably just Marketing wanted to have every possible add-on to tout on the more expensive models. They were usually built a little better regardless, they seemed to have thicker paint finishes that lasted longer, with enamel on the tops of the good ones.
