Another Model Kitchenaid Dishwasher for the experts here to identify
Another potential beauty!
Mark, this is a KDS-21 Superba top of the line(at the time)dishwasher.
Check it out if you can and see how bad the inside of it is. I suggest you keep[ it for all of us on here who have these machines and will need parts for them in the future.
Good Luck
Steve
Talked with the seller. He quoted the model # as "kudp22020". Sounds like a 22 series to me even though he or I may have miss scribed a digit. I know the 21 & 22 are similar. Steve, Thanks again for your help
Up the ladder
Mark, this is a 22 series dishwasher It is basically a 4 cycle machine with Pot/pan, Full Cycle, Light China and Rinse and Hold cycles.
It would be what they used to refer to as the Imperial model
and is nice because it has the rapid advance timer and the cycle indicator lights. They made the same model but with the dial knob timer as well which would have been less expensive.
No sani heat on this one and it would also have the heating element above the sump which doubled as the water heating element as well as the drying element. It has the outside mounted plastic housing blower for drying.
Pump is identical to the 21 series and last of the Hobart designed pumps to be used. The 23 started with the Whirlpool Power module.
Hope this helps
