Anti-Walk/ Anti-Slip feet for washer on concrete/ polyspartic floor
dylanmitchell
Jan 7, 2018
124
Southern California
Please share suggestions for anti-Walk/ anti-Slip feet for a SQ TL. We have a polyspartic coated concrete floor and the machine walks all over. We leveled it front to back and side to side using a bubble level. HP Spartacote Polyaspartic is similar to an epoxy floor but supposed to be more durable. We'd prefer bare concrete but the prior owner put in a big box store epoxy coating that was peeled off and we had to have that ground off and the polyspartic installed.
For the last year and a half, we used the vibration Solutions Sorbothane Anti-Vibration Pads but they've started to fall apart so we're looking for alternative solutions. The SQ TL AWNE92SP113TW01 feet disintegrated but the ones on the SQ Dryer ADGE9RGS113TW01 are just starting to split. The Sorbothane feet pads kept the machine from walking but we didn't notice much reduction in vibration.
Vibration solutions do advertise a 10-year warranty but we haven't been able to reach them, through their support e-mail and their phone rep took our info but no one has called back.
On such small purchases, 10 year warrantys are basicly always just show off and there is no realistic way to ever claim them in a reasonable manner...
Thing is that those feet never reduce vibration in the machine, just reduce transfered vibration to the floor and thus don't do much about your issue.
In your specific situation (solid floor with no give that is verry slippery) a TL has the one great downside that all vibrations produce horizontal forces moving the machine paralel to the floor.
A FL would here probably pose less of a slipping issue.
Dunno about those coatings, but there are solutions to anchor machine feet in place on concrete rizers.
They basicly grib the machine feet and drill right into the floor.
Hard measure, but sure as hell works.
Going to try a rubber mat
Going to try heavy rubber Washer/Dryer Mats. They're 28" x 34" and my machines are 25 5/8 "x 28". Also looked at rubber cal mats large enough to cover both machines. Most of these mats are made out of old truck tires. Rubber flooring inc says they use a part of the tire that doesn't have metal and run magnets by to get metal out that finds it's way into the mix. Any of these rubber mats would probably work.
I was reluctant to get a mat because it's going to be tricking to install in the alcove were the washer dryer sits. But I need to pull the machines out anyway so I can clean the dryer ducting, check connections, and clean the floor before the rubber mats go down.
Rubber feet do dry out and do need to be inspected.
http://rubbercal.com/elephant-bark-rubberized-flooring.html
https://www.rubberflooringinc.com/gym-mat/washer-dryer-mats.html
LG anti-slip squares
I don't know what these are called, but they came with my LG front loader. They have a peel-off back and stick to the floor under the front feet. The machine hasn't moved in 6 months, unlike my previous machine (top loader).
I know Loraine Furniture has tested a number of LG front loaders on Youtube. He may know how to order them or perhaps he has some extras hanging around.
