Anyone know how to clean this classic gas range???
rickr
Mar 12, 2003
4,081
This wonderful old range came out of the "summer home" yesterday. Wasn't as heavy as I thought it would be...
At any rate, the previous owner must have thought this range was a self cleaning model. What should we do with this??
Um, with a blow torch?
LOL.
Seriously. I would try some spray oven cleaner. First remove the knobs and cover up the holes with plastic wrap. Find an oven cleaner that works at room temp. Easy-off sells a thick liquid in a bottle (I found some recently at Smart & Final) that you can brush on, or put into a spray bottle and spray on. It's like lye so be careful. After a few hours, use gloves and a scrub brush to loosen up any stubborn deposits, hose off the exterior (since you have it in the yard anyway) and repeat the process if necessary.
The interior is probably even worse... no guarantee it even works any more... but maybe it's worth a try if you have the time and patience.
Give up??
Well, I did!
I sent Amanda and Dan up north of Detroit to bring this back on Satuday. It is safe and sound in the garage of the summer home for now.
Isn't it beautiful? And in MINT condition! They even cleaned it. Not a chip or a scratch anywhere. And everything works.
Paid $75.00 for the range, and paid Amanda and Dan $150.00 to go get it for me.
close up..
And everything works too!
I was told that this model is from 1964
closer up!
Sorry Rich, I was only kidding.<: I guess I can say early April fool??? lol!!
At any rate, after we moved the old range out, we found an existing 220 outlet for a range! I am having the electric updated, so will check it out. At least we know this home must have had an electic range to begin with. (not that it matters)
There is a bit of snow on the top of the range, and few specs of dust from the ride home. Even though it was under a tarp.
But other than that, it is flawless.
Here is the fridge we will be using at the 'summer home&
An early 1960's Westinghouse I got from Kenny awhile back.
It too is out of my garage, and in storage in the garage at the beautiful "summer home" <:
This old fridge is in very nice original condition, in and out. It will be fine to use with the Frigidaire range.
Now to find an older Maytag set, and appliance hunting will be done. (and that is the most fun part!!)
Probably not from 1964...
because in 1964, the only one who had self-cleaning was GE.
The larger oven is self-cleaning, as can be determined from the door lock lever and close inspection of the control panel.
This is an excellent range, for an electric.
Lawrence/Maytagbear
Rick:
I will wrassle you for that Frigidaire range - best two falls out of three!
Seriously, that is NI-yuss. Probably about '67, not '64. It took a couple of years for GE to licence out the pyrolytic self-clean patents, if I'm not mistaken.
Cleaning gas range...
For the metal parts use gasoline (no match). Gasoline is a great solvant and will remove all the crud from metal parts. Disassemble the metal parts. Put them into a metal pan (like what you would drain car oil into). With a stiff brush clean the parts with small amounts of gasoline. Maybe 1 inch high of gas in the pan.
The Fridedare.... It's beautiful!
ahhh Rick,could the summer guests have a vintage dishwasher too? Nice applicances. :-)alr2903
The previous owners said the range was from 1964. At any rate, it must be from the mid to late 1960's.
The gas range went to the recylers. It was too ugly to mess with.
I don't know about a dishwasher. Maybe. Will wait and see if any room for it is available first.
Hey Sandy, yea, I'll wrestle you for it, but you should know that I seldom loose. Only when if I feel the need to. <:
Dan is working on stripping the house out today. He just found two more guns in the attic a couple hours ago...
Stop or i'll shoot!
Do did the gas line to the house come in later?
Or did the owners convert to electric cooking, say with the stove beofere the one that was removed?
I wonder if that stove was bought used ...
It looks like the Welbuilt that came with the apartment that I grew up in. My family moved into the apartment in the fall of 1959. The stove was there when we moved in. (I have no idea how old it was.) It stayed behind when we moved out in the winter of 1974.
Mike
I think the house must have been built with an electric stove. There is a crude hole in the wall from the kitchen to the utilty room that the gas line ran though. The 220 electrical outlet outlet is HUGE! I will take a photo of it to post when I have a chance. The gas range that we scrapped must have been installed when the old lady lived there in the early 1950's. It looks like a late 40's early 50 gas range to me. It is a Magic Chef, and as I said, it is not as heavy as it looked.
The gas range that I use at my home is a 1937 Roberts and Mander, and it weighs a TON by comparison. My mother used to say that Magic Chef used to be a cheap brand of stove. I think she must have been correct. Magic Chef is still made today, but the quality is seems to be much better.
FRIGIDAIRE Custom Imperial 40 inch range
Rick, Your 40 inch Custom Imperial double oven range was manufactured around 1972.It precedes the 30 inch "Touch-N-Cook"and was a great piece of history. You may want to search ebay for the Meat thermometer for the right oven as well as the rotisery,Spatter free broiler/grill, and be sure the speed heat and Cookmaster controls work.GE pioneered the self cleaning ovens and they were introduced in 1964.By 1966,every brand had them.GE called theirs the "P7 self cleaning oven "which meant P-pyrolitic and 7-$.07/KWH or killowatt hour."FRIGIDIRE called theirs,introduced in 1966, the Electri-Clean oven.Major difference was GE had the asbestos shield between two thermo glass windows and FRIGIDAIRE had the solid windowless models till their final 3 years w/ GM.The wood trim on the 40 inch FRIGIDAIRES was a good way to tell the period they were made. The wood trim was introduced around 1970 through 1975.The went to black trim around 1973/30 inch free standing,Twin 30 and Compact 30 models and 1975 on 40 inch models.I had a GE Americana from John LeFever that was made in 1966 and worked like a horse. I think I made more complete meals with that range than any other range, gas or electric,I ever owned. It had the Rotisery,Sensi-temp burner that could be set for 4",6"or 8" use and worked by setting it by temperature,P7 self cleaning mane oven and removable oven racks in the left oven you could clean along with and inside the main oven!!It also had two outlets,one of which could be programed to come on and shut off automaticly,for small appliances like a hand mixer or coffee pot!I think your FRIGIDAIRE has those same outlets.GREAT RANGE!!!! FRIGIDAIRE BOTHERS TO BUILD IN MORE HELP!!
