Anyone know what year this KA Dishwasher is?
Thanks Martin!
I'm not sure how long it was exactly but the whole cycle was just over an hour. I was just surprised at how short the last wash was. Probably why back in the day we used the extra detergent cups more. Current detergents just say to put 1 pod per load. I used 3 (1 in each cup) of the Sam's club pods when I did the pots/pans cycle because the manual said to do so. But obviously this machine was made before pods lol.
I may switch back to loose powder just so I can divide the detergent better. Though using 2 pods per load isn't a big deal. That everyday the container would still last me almost 2 months
Noise reduction
I ran another load last night (Light Wash) and I noticed that most of the noise now is coming from the control panel. Has anyone put insulation in there to quiet it down? I'm sure there's electrical components so I'd be worried about heat....but that would quiet it down even further.
Hahaha I know right. I'm just OCD that way. My kitchen is open to the living room so noise is an issue. I was just seeing what anyone has tried :-)
Mine too
our kitchen is open to our LR also, matter of fact I can look from my end of the couch and directly see the KA...but that's what remote controls are for!!!!  Personally I like to actually hear it washing.  The Jetclean was noisier than the KA is but at least I know things come out clean in the end.
It's probably now just a tad noisier than my Frigidaire, which is fine. I just like to tinker with things :)
I think I was more exposed to the Whirlpool built KA's because I was amazed at how quiet they were. Of course that was 20 odd years ago and my reference point was probably a lot louder lol.
I love the hum of the motor now!!
Hardly Whisper quiet!
Joe,
Here are some suggestions for you to try.
On the inside of the door, I used something like dynamat rubber padding about an inch thick and custom cut it to fit around the detergent and rinse aid dispensers leaving enough room for the wiring not to be pinches and away from the bi metals.
I have also used 3 inch UNFACED fiberglass and again kept it away from the dispensers.You can actually cover the rinse dispenser with the fg but it has to be thinner.
Since I have a ceramic floor under my machine like you do, I used the 1" thick dynamat stuff on the floor to absorb the sound as well. Fiberglass won't work well and will catch all sorts of dust and stuff.
I covered the lower panel with a piece of rigid fiberglass board cut from A/C ducting and glued it to the lower panel and kickplate, trimming out wherever needed to clear components on the cross member.
If you can, bring the insulation down to the bottom of the machine on the sides and back to the floor leaving an opening for the blower to get an adequate supply of air. Maybe cut it away totally in that right rear corner, Again, thinner rigid board will work better than the looser batt type.
One thing I have tried in the past that worked when the machine was not yet installed was to remove whatever insulation there was and to spray the whole tank with a coating or two or three of Bedliner or undercoating spray. Top, sides, back and bottom. Also inside on the surface of the door. This will cut down on the "ringing" sound that can be heard when the water hits the porcelain tank. Stainless steel has a duller sound when hit with the water.
Of course, I ran it thru a few drying cycles to cure it and get rid of the smell and did it in the garage with the door open so the smell would be gone before installing it.
Then I insulated the tank to conserve the heat and quiet it down further.
I had a Monterey built by WP that had that thick black mastic all over the tank including the bottom and that machine was remarkably quieter than anything Hobart made. I still put the deadening in the door and under the machine. Made a real difference in the noise level in the house.
Ironically, I have a 22 and 23 built by WP and they cheaped out on the mastic as it covers only the top and half way down the sides and back. But for some reason the 23 Imperial is still pretty quiet by KA standards.
You may want to check out Dynamat's website and see if they have something in a roll that you can use too to replace or augment the fiberlas you have on the machine now or in addition to it too.
Hope this helps a bit
Thank you for the suggestions!! I measured the noise level with a decibel meter on my phone (it's probably not completely accurate) and it was reading between 65-70 decibels right now. Most of the noise if from the front. As hard as it was to get that thing installed, I won't be taking it out lol. So I'll have to work with what I can reach from the front. It's installed in an island that faces my living room and like I said all the noise comes from the front of the machine so I'm not worried about around the tank really. If anything I'll pull the lower panel off and see if I can put some insulation along the bottom sides. I'll figure something out for the top panel/door. I like the idea of the Dynamat since I could secure that to the door panel itself. The foiled insulation I have now seems to work ok, but it's not great. The fiberglass does a better job of absorbing the noise. I did try to cut it to fit around the components on the door so I may do that again and then put a thinner material on the panel.
It's not a nuisance at all even as it is now. I could carry a conversation just fine and didn't need to turn the TV up any louder to hear it so I'm not that worried.
Like I said, I just like to tinker with things. I can't work on cars which I love to do, so this is my mechanical fix. LOL
Ok I think I'm done!
So I put some of the pink fiberglass insulation on the door...cutting it to fit around any electrical components. I also stuffed some up through into the control panel...just on the bottom and not near anything electrical. Then I put a sheet of the metallic insulation taped on the top door panel. It quieted it down a few decibels (according to my meter) and it's perfect. You can still hear the water splashing softly and the rhythmic hum of the motor. I'm super happy :)
