Apple Time
westie2
Sep 22, 2004
1,997
In our area apples are now in season. We bought us a bushel of Granny Smiths to make our every other year Apple Pie Filling. This makes around 30 quarts from the bushel so about 5 batches of this recipe.
Canned Apple Pie Filling
In a large stock pot blend:
4 1/2 cups sugar
1 Cup of Corn Starch
2 teaspoons of ground cinnamon
1/4 teaspoon ground nutmeg
1 teaspoon salt
then when blended add 10 cups of water
Cook and stir until thickend and bubbly (keep stiring as it can stick and scorch) Onces it get bubbly and is thickened and clear take off the heat and add 3 tablespoons of lemon juice.
Have ready 6 pounds of peeled and sliced tart apples as they are peeled and sliced dip in water that lemon juice has been added to and them place in a drainer to keep the apples from turning brow.. Pack the apples into 6 quart jars. Fill with the hot syrup. Wipe the jar tops and place on the canning lids and screw on the rings and hand tighten firmly.
Process for 20 minutes in a boiling hot water bath (jar tops must be covered). When time is done take out the jars and sit on a towel for 24 hours to cool. Check each jar top for the ping that tells you it is sealed if it thuds it wil not sealed. When all are tested remove the rings and wash the jars in warm water, dry and place in a cool dark place.
We have a peeler corer that lets us go through the apples pretty quickly and 2 water bath canners.
To make a pie use your favorite pie crust pour in one quart of the filling and dot with butter and cover with top crust. Bake 45 to 50 minutes at 400 degrees.
Our peeler is simular to the picture below. We also have a peeler that attaches to the counter top instead of the suction base.
Using this recipe we have also done peach pie filling.
This was both my grandmothers recipe and passed on down through the years. We have used this for us for almost 30 years.
Apple Butter
If you are making the Apple Pie filling don't throw out the peels and cores. In a large pot place all the cores and peels in with with about a cup of water. Heat to a simmer and place a lid on tow and cook about 30 minutes or until cores are tender we also take off the ends of the apples with with peel like in the aboe picture from the peeler. We used a cone type strainer and place the cores and peels in it and strain out the sauce into a big bowl.
This is the recipe we use.
Oven Apple Butter
9 to 10 cups Apple Sauce
4 to 5 cups sugar
1/2 cup cider vinegar
4 teaspoons cinnamon
Place all ingredients in a roaster. Place uncovered roaster in a 325 degree oven and bake 3 to 3 1/2 hours stiring every 30 minutes. This makes about 10 to 12 1/2 pint jars. Place in jars and put on lids and rings and process in boiling water bath for 10 mintes.
Charles---Those apple peelers are great, aren't they? I have one and it works slick-as-a-whistle. Three or four times a year I make two huge hotel chafer pans of apple crisp and bring them to work. Each pan requires 21 peeled apples, and the peeler makes quick work of it.
Thanks for the apple pie filling recipe, too. I've never canned pie filling, before. However, I have some quart jars leftover from this year's canning, so I'm going to give it a try.
Apple Crisp
Yes this filling is great for Apple Crisp for a 9 X 13 we use 2 of the quart jars of the filling.
What all do you use to make your Crisp topping? I always love the differnt ways it is made.
Apple Butter
Have you tried a slow cooker? My recipe is very similar, but instead of oven-roasting I use my enormous crock pot. The results are awesome, AND the house smells delicious for days.
Crock Pot apple buter
Yes we use the crock pot also and it does make the whole hose smell wonderful for days.
