April 24th recipes.
maytagbear
Sep 5, 2004
6,314
N.E. Ohio
Here they are, from the Pasqua-Easter thread in DL.
Please add a recipe of yours or two. I would like it very much if you did.
Brown Rice and Cheese Casserole
(Slightly adapted from The UCSD Healthy Diet For Diabetes, Algert, Grasse, and Durning. Boston, Houghton Mifflin, 1990)
Cooktop, oven
Can be partially made ahead (rice).
Combine: 2 1/2 cups COOKED brown rice (1 cup raw brown rice, 2 1/2 cups water--follow package directions. Or use your rice cooker, if it has a setting for brown rice. Not all do.)
3 scallions/green onions, trimmed, and sliced crosswise, except for very tops (which are tough, and not usually in a way we like.)
1 cup 2% (low fat in original) cottage cheese
1/4 cup freshly grated Parmesan
1 teaspoon dill weed
1/2 cup milk (low fat in original)
1/2 teaspoon Dijon mustard (I add a bit more, but not a whole teaspoon)
Nonstick cooking spray.
When ready, combine everything but the nonstick cooking spray in a medium bowl.
Spray a 1 1/2- 2 quart ovenware dish, preheat oven to 350F
Add mixture to ovenware dish. Scrape mixture out with rubber spatula.
Bake at 350F for 15-20 minutes. Lightly browned is great, but beyond that, might be very dry.
Exchange values for 3/4 cup with low fat dairy
1 1/2 Starch
1/2 lean meat
1 low fat milk.
Notes: Be sure your dill weed is not too old. Or increase it.
Regular brown/yellow cooking onions are not as successful, but if you have to, finely cut half of one the size of an approximate tennis ball.
Reheats well in the microwave, on Medium.
__________________________________________
Cheddar cheese processor bread
Processor, measures, pan
350F oven.
Shred 4 ounces (half of an 8 ounce package of Extra Sharp Cheddar. Use the shredding disc of the processor, then remove the shredded cheese to a sheet of parchment or waxed paper.
In 12 cup or larger processor fitted with the Steel Knife-"S" blade, combine: 3 cups UNBLEACHED all-purpose flour. I like King Arthur in the red bag for this.
1 level teaspoon active ("bread machine, rapid rise") yeast, 3 level teaspoons sugar(plain white)
1 level teaspoon salt. Pulse for about 30 seconds, or until well combined.
Warm 1 cup milk (preferably whole milk, but 2% will do. No lower!) and 1 tablespoon butter, until butter is melted (about 120F) I use a 2 cup Pyrex measure, and the temperature probe on my Radarange.
Add the shredded Cheddar to the flour mixture, distributing it evenly over the dry ingredients. Cover, and pulse ONCE.
Add 2-4 dashes of Tobasco (I used the last of my Garlic Tobasco), and a teaspoon of Grey Poupon or Meaux mustard to the milk mixture.
Remove food pusher, start processor, pour milk down feed tube. SHOULD combine and make a nice ball. If not, add a little more milk. Let spin for about 35-45 SECONDS. Shut off machine, cover, and put the food pusher in the tube. Let rise IN THE PROCESSOR. Check in 20-30 minutes, and when dough does not fill in when poked with two fingers, re-cover processor, and pulse TWICE to knock the dough back.
Let dough rise again.
I like to make a cottage loaf, and use either a Pyrex cake dish of 9 inches, or a Pyrex pie dish of 9 inches. Spray it with nonstick cooking spray, set aside.
Turn on the oven to 350F. When oven beeps, or you hear the thermostat cycle off, remove dough from processor, and shape into a loaf. CAN use a 9x5x3 bread pan, if you choose. Sprinkle loaf with additional shredded cheese, for a really nice, uncomplicated decoration.
Bake on the centre of the rack, in the centre position. I bake it for about 30 minutes. Should read 190-210F with an instant reading thermometer. Not sure what the baking time would be in a 9x5x3 pan, however. Use your instant reading thermometer.
Let cool in pan on rack for 10-15 minutes, and then remove from pan to finish cooling. As tempting as it smells, don't cut into it until it is nearly room temperature.
This is a very nice, easy bread. It is my standard homemade. Just leave out the cheese, Tobasco, and Grey Poupon for a white bread. Everything else is the same.
Can add 1 cup of whole wheat flour (omit 1 cup of white flour, will probably need more milk/water. I never make it entirely with water. Milk increases the nutrition, the browning, and helps delay staling. If you fiddle with dry milk, it will work, but I rarely have dry milk.
Happy cooking and eating. I have maybe 2 large or 3 sensible servings of the cassrole remaining, and NOT. A. Crumb. of the bread.
Very good, and SO easy! When at room temperature, this will freeze nicely, if correctly wrapped. Makes gooooooooood toast. Cheese variaton makes a magnificent grilled cheese sandwich. White or partial wheat makes a good peanut butter or Nutella sandwich.
I don't bother with the dough blade when making dough in the processor.
I suppose that this dough might make good rolls. I have never had the patience to find out.
This was my first real baking in my new oven (don't consider potatoes or pot roast, or a Stouffer's to be real baking in this context,) and I am very pleased with how the bread turned out.
Everyone who was lucky enough to get some of the bread raved about it!!! Me so happy!!!!
Lawrence/Maytagbear[this post was last edited: 4/21/2011-20:44]
Don't you have a
lime Jell-O, cottage cheese, and crushed pineapple thing? They don't HAVE to be something you made today (or yesterday,) just something tested in the "real world" and delicious.
Or did I write them in a confusing way? I tried to be as clear as I could.
The bread could be made in a 7 cup processor, just that there is room for the dough to rise in a 12 cupper.
Lawrence/Maytagbear
Lawrence, are you requesting a lime Jell-O & pineapple mold recipe?  I have one if you'd like me to post it.  I've also adapted it for cranberry rather than pineapple, and I believe that recipe uses lemon Jell-O.
Not really, Ralph....
I was just a little ??? at the response so far. I guess I was being absurd or silly or something.
I would like it if other people would post a spring recipe or two.
Lawrence/Maytagbear
Creames Eggs
Do this at Easter time when we have the hard boiled eggs
1/3 cup flour 8 ounces grated cheese
1/2 cup butter Soft bred crumbs
2 1/2 cups milk
Melt the butter and stir in the flour to make aq roux cokk about 3 minutes and add the milk while stiring (I use a wisk). Cook until the mixture boils and is thickened add salt and pepper to tast. Add 8 ounces of shredded cheddar cheese and stir until melted.
6 to 8 hard boiled eggs sliced.
9 x 13 baking pan (Pyrex) spray with Pam and place the sliced on the bottom then pour the cheese sauce over. Top with more grated cheese or soft bread crumbs and place in a 350 degree oven for 20 to 25 minutes until it bubbles.
Not really an Easter recipe, but I made this yesterday and it is great! Got this recipe off of Food Network. It is the winning recipe from a Catfish Festival in Louisiana.
Des Allemands Catfish Delight
Fish:
4 c vegetable oil
2 lbs catfish fillets
salt
Lemon Pepper
Garlic powder
1 cup English-style batter mix (Fish 'N Chips batter) plus two cups more (three total)
1 1/4 c water
1 c Chopped pecans
Sauce:
4 oz (1 stick) butter
1 c Chopped green onions
1/2 c Chopped fresh parsley
1- 8 oz can of each: Cream of Mushroom, Cream of Chicken, and Cream of Celery soups - I only found 10 1/4 oz cans at the store.
6 slices cheese - Kraft singles or similar
1 tsp Liquid Crab Boil
1 lb Crabmeat
S & P to taste
1/2 c Pecan halves
Fish: Heat oil to 350 degrees in a deep skillet or fryer. Rinse and pat fish fillets dry. Lightly season with salt, garlic powder, and lemon pepper. Dust lightly with 1 cup of batter mix. Mix remaining two cups of batter mix with 1 cup chopped pecans and water (I usually have to add more water or the batter is too thick. Yesterday, I used beer instead of water and it turned out good). Coat fillets with batter and place in hot grease. Fry until golden brown, about 5 minutes. Set aside on paper towels.
Sauce: Over medium heat, saute onions and parsley in butter for 3 minutes. Add liquid crab boil, soups, and cheese. Cook for 10 minutes. Add crabmeat and cook another 5 minutes. Season with S&P.
Plating: Prepare a bed of sauce on a plate, place a fillet on sauce and partially cover fillet with more sauce. Garnish with pecan halves and parsley.
This is something I tried this evening....
My friend Linn and I were supposed to have Easter dinner together, but she had some time-consuming, but ultimately minor car trouble Easter afternoon. Anyway, we had Easter dinner this evening, April 26th. (We went out Easter evening to a local "family style" restaurant.)
This evening, we had ham, mashed (real) potatoes, and baby carrots. I was looking around Linn's fridge and pantry for something with which to enhance the carrots. I cooked them in cranberry juice and a lump of butter. Very good idea. The cranberry juice was a nice change from orange juice, and was about a kazillion times better than plain salted water.
Some of you may be saying "Sheesh, I've been doing that for years now," however, some of you may say "sounds ok, have to try that." Please do.
Thank you for the replies and comments so far.
Lawrence/Maytagbear
