Asko bellows hose
askolover
Sep 22, 2014
3,811
South of Nash Vegas, TN
I was just looking for ideas to replace the bellows hose on my asko washer. The one on it has developed a hernia...it is very soft rubber and it has expanded such that it no longer is a bellows but rather a large bag that says and restricts the drain pump. I'm going to have to get creative. The pressure dome is also connected to a port in this hose by the pump. I'd like to rig up something more durable as this is the second time it's done this. Any suggestions?
What model Asko?
Can you attach a photo of the offending part please?
Is it the detergent drawer-to-tub hose or the tub-to-pump hose? They are both bellows shaped hoses.
I just might have a good used one here. I will check the shed. If I have one, it is yours free if you want it, but you'd have to pay postage from Australia.
It's asko WM80 model 8005 and it's the tub to pump hose. We use lots of hot water and I think that eventually causes it to expand out like a bag instead of a bellows. Thanks for the links. I'm not in a spot to get a pic of it as it's under the washer and I'm not in that mode right now. I can just see it thru the crack that it's done it again.
