redgeminipa
Hey all!
Our 2005 Maytag Neptune (made by Samsung) recently blew its second pump. In a desperate measure to get laundry done, I picked up this Hoover 519 from a guy on Facebook Marketplace about 20 miles away. He stated it only needed the fill hose, and the price was $50 for the machine. Not knowing anything about these, I figured if it needs anything else, I could figure out a way to get what it needs, and have it up and running. I also decided I'd keep it in the bathroom for small laundry needs, and specifically washing my Norwex cloths.
When I finally agreed to pay him $10 more to meet me about half way, he shows up with it on the back of his truck. As we're unloading it, he proceeds to tell me he discovered the pump belt was rotted, and I'd have to get a new one. When he told me it was like a big O-ring, I figured that couldn't be too hard to find.
I loaded it up, and headed to Lowe's, figuring I could get what I needed to get it running.
I used a phone charger cord to wrap around the pulleys for the pump to get a rough measurement. I ended up getting a pack of various sized O-rings with one that seemed about the right size. Next, I bought one of those handheld showers that fits on a tub faucet, thinking I could use that for the fill hose. It's too small for the piece that goes in the fill hole, but the tube fits down in there perfectly. I had enough supplies to at least test it, so home I went.
I put the O-ring on it, plugged it in, and turned it on. Pump wasn't spinning. Turned it off.
I pulled the pump out, and started taking it apart. I noticed the impeller wasn't attached. It was just floating around inside. There was a lot of lime scale build up, too. The rubber gasket didn't seem too great, but I needed to see if I could get this pump spinning, so I'd deal with the gasket later.
I sprayed a little PB Blaster around the shaft, and let it sit for a few minutes. Then, started working it in. It freed up, and I started putting some 3-in-1 oil in it. It was now spinning pretty smoothly.
Since there was a lot of scale buildup on the lower part of the pump where the seal goes, I pulled out the wire brush for the drill, and started cleaning the crud off. Once that was clean, I started working on the gasket, cleaning it, and hoping it might be usable for now (we REALLY needed to do laundry). I cleaned up around the hole for the impeller, and pressed it back on. Put it all together, and started a small load of clothes to see how it would work.
The wash was great. It spun the clothes very well. This seems to run for 5 minutes on the heavy setting. I ran it two times. The clothes then went into the spinner. Since I was outside on the back porch working on it, I had the hose laying on the ground. When drain and spin started, water was coming out of the hose, slowly, and out from underneath the washer. The pump was leaking. Since I had a small load of clothes that were wet, stuck inside the MaySung washer for 5 days, I had to get those washed. I just continued to wash those, and called it a night.
The next day, I went to a local hardware/surplus store to see if I could find an O-ring to use as a pump gasket, get new hose clamps (those pinch clamps are horrible to work with), and a new drain hose, since the original was pretty bad. When I got home, I pulled the pump back out, and started cleaning it up with a new gasket. Everything was put back together. When I turned it on to pump, there were no leaks. It was time to take it in the house, up to the bathroom.
Once we got everything set up in the bathroom, and washed a small load to test it, I discovered the pump didn't seem to be working. I forgot to put the "belt" back on... Once that was on, it pumped really hard for a few seconds, then went back to a trickle. Nothing was draining unless we put the hose nearly to the floor.
I was leaning towards maybe the impeller might have popped off again, as I didn't clean the hole too great, and it wasn't pressed on very tight. So, this morning, I pulled the spin tub drain hose off, and... the impeller was laying in there again. I pulled it apart again, and was determined to fix it. I scraped the inside of the impeller hole clean with a razor knife, and put a few drops of Loctite Quicktite Gel inside, and firmly pressed it back on the shaft. I closed it all back up, and installed it again.
Presto! Problem solved, and it's working like new, with strong pump pressure for draining both tubs. Now, I have no idea how well the big O-ring will hold up as the pump belt, but the variety pack from Lowe's was only around $5, so if I get a month out of it, $5 per month (for now) is quite manageable. I may buy another pack to get the sizing to search for more of that size O-ring online, and stock up on them. I may even find some at the hardware/surplus store, and they average about 25¢ each, so that could be pretty cheap for a dozen of them.
There are some other minor issues I'd like to address over time, such as the rinse/spin control is broken off where the knob rod connects to it. No big deal right now, as the water still pours in if I have the faucet turned on.
I'll only be using Norwex Ultra Power Plus laundry detergent in this, as it rinses clean, and won't leave a buildup. It was also breaking up years of buildup from inside the Maytag, which I'm kinda wondering if that's why the original pump failed.
