Asko W6461 snapped spider
hotpointwma64
Active member
Jan 19, 2014
44
North Yorkshire
I purchased an asko washing machine w6461 with a blocked pump and paid on paypal stupidly as i never thought a machine with a stainless steel drum spider would have a problem with it!
not alot of movement but theres a bit and it bangs when spinning, but i cant find a spider ANYWHERE.
no spares websites sell asko spiders- and thats the ones that actually sell parts for them at all.
Please help me find one if you can:(
thank you in advance
Where did you buy it from, and have you tried asking for your money back if you weren't told there was a problem?
You could try asking the UKWhiteGoods guys, as Asko make the ISE machiens for them.
Hi, i bought it from ebay and did actually check the machine over before i took it away, silly me thought it was just the drum going back and forth a bit like zanussis do so it was my own error of judgement.
Thanks i will ask them:)
George
I found a parts diagram for a similar model, but unfortunately no separate drum spider is listed. It looks as though you have to buy a whole new inner drum. Would definitely ask at UKWhitegoods though just in case they know any better.
Tom
Asko
How do you know its the spider? have you taken it apart?
I would be very surprised if it was - did you transport it on its side or stood up? more likely you have twisted one of the four legs during transit, I would take the lid off (first unplugged) and see if the drum looks centred and in-line and press it down to see if the shocks are okay....
"Not a lot movement but there's a bit and it bangs on spinning..."
I'd be mighty surprised at an Asko having a failed spider.
If the main drum bearing had really badly failed (balls or rollers come out) then the inner drum would bang around on spin.
Also like Mike I'd suspect a suspension strut - failed, or come apart in transit.
Another more weird possibility is a broken strap that holds the drum to the base - if you look at Mike's photo you can see that on top of the four struts there is a flat-ish steel plate, and the stainless steel outer drum sits on that. The drum connects to the base plate with two flat steel straps right over the top of the drum. If one strap is failed the drum will bounce on the steel plate.
Another option is a failed motor mount - Askos have rubber cushion mounts to absorb motor vibration, they can fail. It all depends if what you are seeing is really a loose drum, or just vibration from a loose component (motor, or cast iron stabliliser weight) banging the drum around.
My knowledge of Askos is based on an older model (I have a 12004) but they are more or less the same construction, with more sophisticated controls and circuits on the later models.
Snapped spider
If the spider really HAS failed, It should be a 10 minute job for a good MIG welder to repair it. Stainless will weld well, not so for aluminium.....
All best
Dave T
Hi no its definately the spider, the bearings are fine and so are the shock absorbers- it is movement between the drum and tub. I was shocked too and im guessing thats why theres no listing because its so rare. Ill take the drum apart and see for definite and i do know a welder so thank you for all your helpful advice.
If you bought it from ebay and via paypal, you should be able to claim some money back, although I'm not sure whether the onus would be on you or the seller to say whether the issue was there when purchased/collected.
Have you worked on an Asko machine before? If not, may be worth getting a 2nd opinion .
I arent too bothered about claiming money back because at the end of the day i did check it but didnt notice.
Ive worked on alot of machines but never anything like asko, its a very interesting machine and it seems quite simple really i am nearly ready to get the drum out to have a look when i next have some time.
Thanks for your advice and i will inform you all of what happens, and it gives me piece of mind that i can just get the spider welded.
george
I have taken the drum out and it seems where the spider grabs the wedge on the edge of the drum it has come loose, does anyone have any suggestions as to how to make it grip properly again? Im not strong enough to do it with my adjustable grips:(
Is the spider riveted onto the drum? If so it might be possible to drill out the rivets and replace them with stainless steel nuts and bolts.
Maytag MAF8805
Mine has just come that I bought on ebay and it has a noise when tumbling in the wash cycle and when distributing for the spin. THe actual spin cycle is silent.
The suspension is absolutely fine but I have noticed that there is play in the drum, the drum moves up and down a couple of mm's between the outer drum. Is this catastrophic and is it gonna cost a fortune to get repaired?
How did you fix yours please?
hi richard,
its nothing serious at all, its basically just where the spider connects, its a secure connection its just a tiny bit loose, its not coming off any time soon.
Dont worry about it- after fixing mine it didnt take long for the noise to come back and its worse than yours is! it would worry me seriously on any other machine but it doesnt because i know its safe.
Yours is probably still like new underneath, as is mine. :)
YouVe put my mind at rest a bit there now. So even if it's loose a bit it won't get worse then? Can I reduce the wear and tear by lowering the spin from 1600 to 1200?
Have you the same machine, yes it's like new when the cover is off and at the front also. I don't think they even do spare drums any more as had maytag service out today before. I've entered a service plan with them for £28.99 a month for a year. First call out which is this one if they can't repair it due to not having the parts or write it off then it will be cancelled.
Wish I had held fire now cos they may come back and have the parts. The display sometimes fades too.
Problem is mike spares are not available for this model any more... As confirmed by maytag and uk white goods and parts are not interchangeable with different models. I even asked if the same size drum ise10 1606w would fit as it's the same drum capacity and litres but they wouldn't tell me. :(
Regards
Richard.
mike i worked as an appliance engineer in a refurbishment warehouse, if you get an asko and look at how the spider is assembled then youd see that it i completely safe. its completely fine its completely different from any normal spider too.
Can you give us some more information to back this up, its ok saying that but would be good if you could go into detail as to how it is constructed etc. Why is it different from any normal spider etc.
