ATC Temperature Targets
DADoES
Moderator
Staff member
May 21, 2001
16,520
TX, U.S. of A.
As a corollary to the discussion about tap hot water temperature.
There are 20+yo machines with ATC but most are newer so topic is here.
My F&P IWL12 (a Phase 6 model, circa 2004) directly moderates the valves to attain the mixed target temperature.  Thus for example, Warm fill spraying out of the flume is 115°F if the incoming hot supply is at least that temperature.  Cold and Warm/Cold could be higher than the target if the cold supply is higher.  The target temps are adjustable (en masse, not individually) on a range of +6°C to -6°C in 2°C increments.
- tap Cold
- 16°C/61°F = Cold+ (controlled cold)
- 34°C/93°F = Warm/Cold (cool)
- 46°C/115°F = Warm
- 51°C/124°F = Warm/Hot (medium)
- 69°C/156°F = Hot (essentially tap-hot)
My AquaSmart (a Phase 7 model, circa 2009) is more crude in that it doesn't directly moderate the mix.  It runs tap-hot (Warm, Warm/Hot, Hot) or tap-cold (Cold+, Warm/Cold), moderated with mixed/warm to attain an average around the target.  Thus, a delicate or synthetic load on Warm will have tap-hot (or near so) water spraying on it at times during the fill.  Target temps are not adjustable.
- tap Cold
- 18°C/64°F = Cold+
- 30°C/86°F = Warm/Cold
- 50°C/122°F = Warm
- 56°C/133°F = Warm/Hot
- 62°C/144°F = Hot
My older GWL08 (a Phase 4 model, circa 1999) moderates the valves.  The target temps are best as I can determine per Phase 3 documentation.  Target temps are not adjustable.
- Tap Cold
- 29°C/85°F = Warm/Cold
- 35°C/95°F = Warm
- 40°C/105°F = Warm/Hot
- 49°C/120°F = Hot
Whirlpool Duet WFW9750
ATC Temps:
Normal/Delicate/Silk, Handwash, Wool
Cold: 75ºF
Warm: 85ºF
Hot: 100ºF (starts with tap hot and adds cold as needed)
Bulky, Whites, Heavy Duty:
Cold: 85ºF
Warm: 105ºF
Hot: Tap (~140ºF since it is next to the hot water heater)
Forgot to mention
The Sanitize temperature heats to about 150ºF, and then runs a 'steam' portion that heats the small amount of water to 160ºF. I would much rather it heat the main wash to 160F instead.
