aegolden
I have a G.E. Liberator with four burners. Three are push button controlled and the last (on the left front) is controlled by a rotating dial. In the center of the left front burner is a small hydraulic pressure sensor, which I understand is supposed to help regulate that burner’s temperature. I need to replace that left front burner, but I can’t seem to find any burners in housings that leave the necessary hole for the little hydraulic pressure sensor to come through.
I’m not sure if these have a special name but I’ve tried e.g. “automatic calrod burner”, “calrod with center hole”, etc.
If I can’t find a burner that has room for the pressure sensor I’m also open to removing the pressure sensor and installing a “normal” burner, but I’m not sure if the pressure sensor is critical to that burner functioning. I see one thin wire running from the sensor towards the back of the stove. I’m not sure what to expect if I were to (for example) remove the sensor and just ground that wire.
Any ideas? Thanks for any help!
