With gas ranges, the plumbing, valves, orifices and burner heads are so distinct that changing that is an almost impossible project. The little stamped aluminum burner heads could not take the heat of a higher BTU input without melting. In older ranges like the Crown, all of that piping under the cooktop was cast iron. In these, it is aluminum or worse.
