Cree spectral notching for higher CRI...
From the linked PDF:
1. What is Color Rendering Index?
Color reproduction is an important characteristic of any type of lighting, including LED lighting. Color
reproduction is typically measured using the Color Rendering Index (CRI). CRI is measured on a scale up
to 100. The higher the CRI, the more accurately you will see the actual colors of objects that the bulb
illuminates (i.e. reds will look red).
Daylight has the highest CRI (~100), with a 2700K incandescent bulb being relatively close, and
fluorescent lighting being much less accurate (CRI 70-85). Certain types of specialized lighting, such as
sodium lights (street lights with yellow orange colored light) exhibit a relatively low CRI (as low as about
CRI 20 – 30). The Cree TW Series LED bulb has a high CRI of 93, unmatched for LED bulbs, making colors
look the way they were intended.
2. Is there such a thing as good CRI and poor CRI light?
The higher the CRI of a bulb, the more accurately you will see the color of objects illuminated by its light.
According to ENERGY STAR®, a bulb with a CRI of 80 is the minimum acceptable for ENERGY STAR
qualification. According to this standard, anything below 80 could be considered poor CRI light. A light
bulb with a CRI of 80 is a excellent general use bulb for the home.
4. So then ANY 80 CRI bulb is good?
Not exactly, not all 80 CRI bulbs are the same. LEDs produce light with broad a color spectrum, like
natural light has, while CFLs have very narrow bands of color, forcing your brain to fill in the missing
color gaps. Many people find this disturbing without even knowing why. Both may have a similar CRI,
but in fact the CFL light is a much poorer quality of light.
7. The Cree TW Series bulb achieves high CRI through spectral notching, what
does that mean?
The addition of neodymium in the glass of the bulb affects the LED light passing through the bulb to
create a “spectral notch”. A spectral notch is a portion of the color spectrum where the light is
attenuated thus forming a "notch" in the spectrum. By notching a portion of the yellow light, you get a
higher contrast between reds and greens which brings out the true colors of what is illuminated. What
remains is LED light that has a higher CRI.
http://www.creebulb.com/Content/downloads/product_info/TWseriesFAQ.pdf
