geoffdelp
Hi Everyone ... Here is the what I managed to get started on this weekend. I got the cabinet off and started to pull everything apart.
I like the ease of getting to everything; it is all very gunky. You should have seen the stuff come out when I tipped the whole unit over onto the drive. I used the pressure washer to get inbetween the tubs and the basin and there were globs of black gunk that poured out.
The agitator is stuck and I'm afraid I'll have to cut it out. I tried to get the Agitamer underneath, but to no avail. There is so much dirt, etc. under the agitator that the Agitamer won't fit. I'm very disappointed, because I think that this agitator is in really good shape. Red bakelite!! Once I get the agitator off, I can lift out the porcelain tub and clean, clean, clean. The torque clutch and braking system look almost perfect!! No need to disassemble.
I've pulled the motor off and will drop it off to be gone over thoroughly. The pump is fine and you should have seen the stuff come out of it!! GROSS!!!! The hoses are shot, but I expected that.
I'm really enjoying this process and am learning a lot. I can't wait to work on it more.
I have a friend who does electro-coating of metals and will have him do the cabinet and lid. The top console panel is near perfect and cleaned up well with No. 7 white rubbing compound.
I'll post another picture of the base near the water inlet; it's fairly water damaged.
Maytag sure made a solid machine; very heavy!!!
Geoff
Geoff
