Beko Heat Pump DPU 8360W - Tangling Bedding into a ball
richardc1983
Oct 31, 2009
497
Leeds, UK
Ive had the dryer now nearly a year. Warranty nearly up but a question for you. When your drying bedding consisting of 4 pillow cases, fitted sheet and duvet cover I find this dryer tangles them all up into a ball... That's also with me ensuring that the buttons to the duvet are fastened so things don't go inside, they still roll into a big solid ball.
I expect the issue is because its only got 2 drum paddles or the fact the reverse tumble only lasts literally 5 seconds before going forward again.
Has anyone else had this issue with any other dryer and how do you get around it? Only way I can see is to dry the sheet/duvet cover separately and then put the pillow cases in with a normal load of clothes washing?
This always happens to me when you only dry JUST bedding in one load regardless of whatever reversing/uni directional dryer i may be using.
Remember that your Hoover takes 4kg and the Beko 8kg so really you ought to be putting 2 loads worth into the Beko.
Always mix a duvet cover with lots of smaller items and it shouldnt happen.
So maybe save wash day until you can get 2 loads washed and into the dryer for the same cycle, should solve the issue completely.
Shirts, t shirts and other similar fabric mixed with bedding should be good to go.
It always happens to me also in my Bosch which does not reverse at all. I go crazy!
It happens also if I do a mixed load. It's even worst because the small pieces ends up inside the "ball" and they get even more wrinkled.
So I ended up line drying for a period of time and than when the duvet or sheets are still damp but not completely wet I put them in the dryer.
When damp there is less "friction" on the fabric and everything tumbles more freely.
We have the standard condenser version, and have never had issues with bedding rolling into a ball the odd time that I dry bedding in the dryer. However i tend to dry most things either on the horse or on the line, weather permitting - so wouldn't be able to report any ongoing trend.
Jon
This (video) should help
The only tumble dryers I didn't hear do that are Vented Hotpoint/Indesit, all Mieles and all Candy/Hoover, probably because they all reverse for a minute or more
...I've tried this as my Whirlpool AWZ 3303 has the same balling up problem with drying sheets. Although it takes 6-7 minutes for sheets to ball up again,it still helps :)
Dex
In the 18 months i've owned my BOL Indesit dryer I've only once had bedding roll into a ball, this was my fault for not shaking the load out. My dryer has two paddles also but they are wave shaped and off set from each other so as to move the load in a figure of eight movement, this coupled with reverse tumbling for equal amounts of time ensures fast even drying.
Intrigues me to know why BSH group dryers don't reverse.
Most dryers reverse even for a short time... but Bosch/Siemens! Has any1 ever tried to complain to Bosch/Siemens for the lack of reverse action in the dryers and obtained a response? I'd be really curious to hear it... there must be some valid philosophy behind...
@gorenje, does yours run the entire cycle revolving in 1 direction... or does it occasionally stop and carries on in the same direction?
The BSH dryers don't reverse, and someone I knew asked them why, and they said that they would be drying as effective as the others there and the little plastic thing in the back of the tub (which was added about a year after the dryers were launched) would prevent balling. Further, they do 2 stops at the beginging, then run on without stop till irondry, than the number of stopps increases with advancing drying time.
But it happens all the time! Some times this problem resolves it self (you can see the load balling up and then, the ball dissapears again), but sometimes, it just stays as it is.
I mostly dry the duvet- and pillowcovers together (2-3 sets), than I run the bedspreads seperatly (2 at one time usually), maybe some toweling mixed with it. Mixing helps as well as closing everything up comletly, not over- or underloading and zippers on you beddings help either. And seperate non-closeable, big items like bedspreads serperatly!
Once I tried to mix heavy (towels, jeans) and light (shirts, socks etc.) items, and this seems to work best. The heavier ones are mixing the lighter ones through, as long as you have the right mix (about 40/60 to 50/50, this is what works best for me) .
I have one of these infamous BSH dryers and have found that I can dry pretty much anything BUT large, lightweight items. For the past couple of weeks, I have dried fitted sheets alongs with towels and other small items (underwear) in one load and didn't have problems. Sure, some stuff like wash cloths will get caught in a fitted sheets, but that's to be expected. Also loads of just bedding (pillow cases + duvet covers) dry without problems, as long as it's not that lightweight microfibre stuff from non-reversing dryer hell. This stuff balls up no matter what. Dryer balls don't do nothing.
I have found that larger loads are less likly to ball up, simply because itmes don't have enough room to tangle.
Alex
Thanks guys for addressing the BSH mystery.
So, the stopping and starting of the drum together with some loading tricks would... well... do the trick! Personally I don't take any particular measure to load the dryer, however, I always shake open item by item as I'm taking them out of the washer... this takes me to my next point...
I don't mean to hijack this thread and I apologise in advance if I'm slightly doing so... it's just a little thought I had for a while and it didn't seem worth starting a new blog for it... and now all this talk about the lacking of such a popular feature in dryers reminds me of the lack of another popular feature on washing machines: I'm talking about the anti-crease soft disposal tumbles that all front loading washers do at the end of the cycle... whereas modern Hoover/Candy washers don't include in their programs (but on delicates briefly). I'm intrigued here by reverse phsycology, having also used non-Hoover/Candy washers, I've noticed no difference in the outcome (apart from the shaking described above): so there I am questioning the usefulness of this added phase... um... maybe I should start a new thread :-P
I have the same heat pump dryer
and it too rolls all the bedding and any other large items into a ball, I check it when it says finished and nearly always have to restart the cycle after untangling the duvet cover, Oh and have tried all the tricks of the trade to no avail.
Austin
@ Haxifan
My Bosch dryer occasionally stops for a few seconds but than carries on in the same direction.
I have a model without the conus on the back of the drum. But my father has a brand new heat pump Bosch dryer with the conus added on the back of the drum, but there is no difference in tangling. Its tangles like mine does.
Thanks for the comments and suggestions guys.
I think what I am going to do is wash the duvet cover pillow cases and fitted sheet separatly and then do a normal clothes wash.
I will then place all this into the dryer at the same time apart from the fitted sheet as it seems the fitted sheet and the elastic is what causes it to ball up.
The fitted sheet can go in last on its own I don't think will take long to dry this.
The problem with a heat pump dryer is that it takes a long time for the heat to build up inside due to how the technology works as it isn't instant heat due to not using heating elements. So opening the door (which the manual says not to do during cycle) releases the build up of mild heat. It dries at a lower temperature as well. So starting the cycle again means that it has to then build the heat back up.
I could even put the fitted sheet over the door during the first drying cycle so it gets a head start.
From research online people seem to say it is the fitted sheet that is the culprit. Ive put mixed loads in before with the fitted sheet and its just balled up all the same so drying the sheet on its own is the only thing I haven't tried yet.
I will report back :)
Every dryer I ever had rolled sheets into a ball. Just have to go every 15 minutes and untangle them. Didn't bother me.
PS, I never had a bidirectional dryer, might help, might not.
Beko Dryer
As may have been observed from one of the other threads I have had one of these too, for just over a year. I think the balling of the sheets must be as a result of the elasticated edges, I cannot recall too much of a problem with duvet covers although I usually dry bed lines on the line if I can - not much recently though with all the wet weather we have been having. Usually when I am frying sheets & duvet covers in the dryer I will open it up half way just to check if things are being tangled.
I was surprised though when I used my 1980 vintage Philips 162 dryer (as I have done a few times) for, although it is not a reversing dryer, it does not seem to ball and tangle up the clothes very much - really not much more than the reversing dryers I have had in recent years
Al
I have a 3 year old vented hotpoint. It spends a few minutes turning in one direction then a few minutes in the other direction and I've never had a problem with tangling. I did have a condenser white knight dryer that I had to get rid of after a year as it used to tangle everything esp bedding. It would only reverse for a few seconds.
Balls
I had an AEG lavatherm computer controlled thingy once and that only reversed oaccasionally and then only for a few seconds, and would ball up sheets etc............
My Hoover D6144 reversing dryer doesn't ball up sheets etc.........37 secs one direction and 37 secs the other...........
Tangles
My Lg dryer does the same thing, all bedding in a huge tight ball. Same prob I had with a vented beko I used to own and the white knight and the Hoover.
The only dryer i've had that didn't do it was my Hotpoint/Indesit which doesn't do short reverse tumbles like most dryers do. There appear to be few that do true reverse tumbles but that is something Indesit got right.
I just take the bedding out halfway through give it a shake out and untangle etc and then back in. It's a pain but the only way to dry it in a machine like these.
Steve
I washed and tumble dried the whites today, consisting of our duvet cover, 4 pillowcases, fitted sheet, 2 bath sheets, a few t shirts, the bathmat, a couple of hand towels and some underwear,  on the Normal dry setting it dried everything fine without tangling/balling up.  I have to say that despite reversing infrequently, it tangles and balls up less than the old Miele dryer (and also my mum's) that supposedly have "intelligent" drum reversing which reverse whenever it senses the load tangling up.  There hasn't been a load combination yet that the Beko hasn't been able to deal with evenly - but then like I mentioned before probably not even half of our washing ever sees the tumble dryer.
Now if only there was a tumble dryer that did the ironing too!
Jon
lavamat_jon
What sensor programme setting do you have the beko on? I have found that cupboard dry leaves things damp. So I set it to Extra Dry which usually adds another 8 minutes onto the cycle which ensures everything is dry.
Same with my Siemens - I have it set to Cupboard Dry + 1, which adds five minutes to the heating cycle after the clothes have reached the set dryness level.
Did four loads today (two for the washer but four for the dryer):
- towels, fitted sheets and some small items like underwear etc. -> one small towel got caught in a sheet but everything came out fine otherwise
- first batch of cotton bedding (two pillow covers and two duvet covers) -> no tangling
- second batch of heavier covers -> some tangling but everything was dry... and wrinkled
- third batch of lightweight covers -> didn't even take a minute to roll into a ball. Pointless. Seems the problem is that the fabric gets sucked onto the lint filter and stays there, while the drum twists it into a rope.
Video to follow.
...tangle free...
Well seems I struck it lucky as having read all the above and never having experienced a "balling up" event in my AEG Protex Dryer I though it best to see what it actually does...I like to dry things seperately and never seem to have more than 2-3 kg's in my allegedly 9kg dryer so that things can tumble/move around properly. It does have a "Bedlinen" setting which I add 2 "+'s" to to get it fully dried. It tumbles clockwise for 1 min and then reverses for 30 seconds... thus seemingly being more than adequate to avoid balling up. The other settings (save the wool and gentle) tumble clockwise only. Oh btw that's with drying a super king fitted sheet, flat sheet and 2 pillowcases - which according to comments should be really good candidates for balling....my E-Lux/AEG's may not have the german old school build quality anymore (faultless operation 15 months sofar but still early days) however still seem to have AEG intelligence.
The only thing that sometimes balls up in my dryer is one particular microfiber blanket. If it balls up, I just flip it over so it unwraps itself.
I divide towels and sheets into separate loads, so I can't say if they would tangle in my dryer if dried together.
Zanussi
My Zanussi TOL dryer is very good and very delicate. Dries evenly and happy out. It does the reverse for like 10 seconds then back the other way. It does tangle bedding and the sensor drying programmes tend not to be great for the old king sized duvet covers but I find the opposite that If I dry my bedding on its own it will dry evenly.
It's B rated, but I've found it super econical, we line dry all summer long but in winter our garden catches feck all light, and it's on the whoel time. But I've yet to get a high electricity bill. Bi monthly our bill never goes above €80!
There are too many programmes in truth and I wish I could see my laundry drying!
I do miss my old TL61 though.
Well the results are back... drying without the fitted sheet in means no tangled bedding.
I don't have enough washing to put two loads in on bedding day as the darks takes up the full load and there isn't that many whites so I do try to put as much in as I can.
The fitted sheet was put over the door to air dry while the dryer was on then the sheet put in on its own for half hour after to dry off. Works fine :)
