Jed -
I thought that was at least partially your pump too. Dissappointing that it's not. That noise is coming from one of only four places - the motor, the basket drive, the pump, or the transmission. It sounds like a bad bearing.
Since you have a new pump and an old noise, we can eliminate that as a source. I would not think this is a basket drive noise, and with the motor's hum that I hear also, I think you're on the right track.
BUT, the bad news is 3-speed motors are NLA, and have been apparently for a while. They were stupidly expensive anyway. Good news is they're the round ones and are serviceable. My recommendation would be the same to you that I gave to Delmer - see if you can find a little shop somewhere that loves to work on that sort of thing (the guy I used was fascinated that I wanted to fix a 1960-made motor for an old "worsher" and he did it gleefully).
If you want to verify that the motor is the problem, I would pull the motor (VERY easy) and swap it with the motor out of your 24-inch machine if you still have it, or some other 2-speed motor. You'll need to swap the pulleys, which are installed with set-screws. This will confirm whether or not the noise is the motor, and you'll be able to use the washer while the motor is out. You will simply not have the 3rd speed (leave the third wire secured but not touching anything).
I can tell you how to remove and re-install the motor if you like - just let me know.
Gordon
