surfing thru surfactants
It's true, the Bendix and the other tumbler machines from that era did not clean outstandingly well with soap in any water conditions.Then, when synthetic detergents came out,they were so sudsy that you had to cut down too far to prevent oversudsing,thus compromising efficiency.Afterwards, came the low to moderate sudsers, such as Spin, All,then Dash,which took time to perfect,for they were not at first tops in cleaning, a fact which later changed. With one of today's excellent HE detergents or a low sudser from the 1960s-up, these vintage beautys can do a wonderful cleaning job.A cut above the rest to begin with, even with the syndet's limitations was the Bendix Duomatics thru 1958.Why?Because the drum was much larger, causing clothes to plunge two feet as the literature stated,thus it cleaned at least as good as a standard top-loader of the day.
