See LG's 1st Top Loader with an Agitator in action. Complete cycle of a load consisting of Bath Towels, Hand Towels, a Robe, a small Blanket, a couple Pillow Cases & an Oven Mitten. Use the time links below to skip to different parts of the video.
I have the Silver / Graphite Steel; model WT7305CV, but this washer also comes in White model WT7305CW.
The Cycle Selector Knob was turned to "Heavy Duty". The Heavy Duty wash program cycle had the following options enabled.
Turbo Wash = On.
Water Level = Deep Fill (not Deep Fill Max).
Wash Temp = "Warm".
Spin = "Extra High".
Soil = "Heavy".
The following technologies you will see the washers perform is...
TurboWash 3D™:
TurboWash 3D is the collective group name of 3 LG features. The 3 features that make up TurboWash 3D is WaveForce (08:08), TurboDrum (31:08), & SmartRinse Jet Spay (01:10:48).
WaveForce™: see it in action @ 08:08.
During the wash cycle the tub and agitator will start to spin in the same direction and at the same speed. Please note that this new implementation of the WaveForce feature does not spin the water to the top of the tub and allow it to spill back over the load like some of the other LG washer that have "WaveForce".
TurboDrum™: see it in action @ 31:08.
The TurboDrum feature is the way that the agitator and the tub rotates independently and in opposite directions.
4-way Agitator: see it in action @ 31:08.
Specially designed fins create a unique 4-way wash action that moves clothes left and right, up and down for a thorough clean that’s still kind to clothes.
6Motion™: see it in action @ 31:08.
6 different wash motions, each designed to get clothes cleaner and help them last longer. 6Motion technology combines a variety of agitation motions for outstanding performance and versatility.
SmartRinse™: see it in action @ 01:10:48.
The SmartRinse™ jet spray system forces water to penetrate through and into the close as the tub spins for quick and thorough rinsing. The smart rinse save time due to the tub not needing to fill with water before performing the rinsing.
950rpm Spin Speed: see it in action @ 01:18:30.
The 950rpm max spin speed will help the clothes dry faster, due to more moisture being removed during the high speed spin cycle in the washer.
00:00 = Loading the washer.
00:33 = Adding Detergent to Dispenser.
00:47 = Wash Settings.
00:54 = Cycle Start Chime & Lock engaging.
01:02 = Load Auto Sensing.
02:06 = Turbo Wash Cycle: Detergent dispensed & initial water added.
04:22 = Load Auto Sensing.
04:41 = Water added 2nd time for Wash Cycle.
05:43 = Turbo Wash Cycle: feat. TurboDrum™ & 4-way Agitator with 6Motion™.
07:19 = Water added 3rd time for Wash Cycle.
07:33 = Turbo Wash Cycle: feat. TurboDrum™ & 4-way Agitator with 6Motion™.
08:08 = Turbo Wash Cycle: WaveForce™: Tub & Agitator spins in unison clockwise.
08:54 = Turbo Wash Cycle: WaveForce™: Tub & Agitator spins in unison counter-clockwise.
09:38 = Turbo Wash Cycle: feat. TurboDrum™ & 4-way Agitator with 6Motion™.
12:23 = Turbo Wash Cycle: WaveForce™: Tub & Agitator spins in unison clockwise.
13:13 = Turbo Wash Cycle: feat. TurboDrum™ & 4-way Agitator with 6Motion™.
20:38 = Turbo Wash Cycle: WaveForce™: Tub & Agitator spins in unison counter-clockwise.
21:25 = Turbo Wash Cycle: feat. TurboDrum™ & 4-way Agitator with 6Motion™.
28:54 = Turbo Wash Cycle: WaveForce™: Tub & Agitator spins in unison clockwise.
29:37 = Load Auto Sensing.
30:12 = Water added 4th time for Wash Cycle.
31:08 = Turbo Wash Cycle: feat. TurboDrum™ & 4-way Agitator with 6Motion™.
38:14 = Turbo Wash Cycle: WaveForce™: Tub & Agitator spins in unison counter-clockwise.
39:06 = Load Auto Sensing.
39:32 = Turbo Wash Cycle: feat. TurboDrum™ & 4-way Agitator with 6Motion™.
47:40 = Turbo Wash Cycle: WaveForce™: Tub & Agitator spins in unison clockwise.
48:32 = Turbo Wash Cycle: feat. TurboDrum™ & 4-way Agitator with 6Motion™.
52:18 = Turbo Wash Cycle: WaveForce™: Tub & Agitator spins in unison counter-clockwise.
53:09 = Load Auto Sensing.
54:14 = Turbo Wash Cycle: feat. TurboDrum™ & 4-way Agitator with 6Motion™.
56:23 = Turbo Wash Cycle: WaveForce™: Tub & Agitator spins in unison clockwise.
57:15 = Turbo Wash Cycle: feat. TurboDrum™ & 4-way Agitator with 6Motion™.
59:22 = Turbo Wash Cycle: WaveForce™: Tub & Agitator spins in unison counter-clockwise.
01:00:14 = Turbo Wash Cycle: feat. TurboDrum™ & 4-way Agitator with 6Motion™.
01:01:20 = Turbo Wash Cycle: WaveForce™: Tub & Agitator spins in unison clockwise.
01:02:09 = Turbo Wash Cycle: WaveForce™: Tub & Agitator spins in unison counter-clockwise.
01:02:54 = Turbo Wash Cycle: feat. TurboDrum™ & 4-way Agitator with 6Motion™.
01:03:59 = Tub Drain Cycle: Drain Pumps On.
01:06:30 = Tub Drain Cycle: Tub Spins while draining.
01:10:00 = SmartRinse™ Cycle: feat. Jet Spray System.
01:13:21 = Spin Cycle Starts.
01:18:30 = Max speed of 950rpm reached
01:23:00 = End of Cycle Signal Chime.
