slowspin66
The other afternoon i was using the Bendix and there was a very odd smell coming from the machine when the heater was on, eventually the heater stopped working. I thought today i would have a look and as there were a few bits that needed adjusting i thought a service would be ideally timed.I did a major restoration a few years ago, but every few months or so the machine has to be un bolted from the floor and adjusted. One of the wires had burned through on the heater so a bit if a snip and a trim back sorted out the connection. A couple of years ago the three way switch that operates the heater and motor also failed and needed a repair that i knew at the time would only last a short time. I made a call to David at Electrical sales and surprise surprise he had a replacement switch!!!! That went on a treat and with an oil change in the gear box the machine was back together again.!!! A water and electrical test and the machine was bolted back down to the floor.
One of the things i did during the full refurb years ago was to replace all the hoses and the rubber seals except the door seal and the soap port hose. I replaced part of the soap port hose but not all of it. I used a rubber bush cover from a car steering column to make a partial replacement however the piece that holds the metal strainer had to be retained. This part along with the door seal is looking a little tiered and think before long will need replacement.
Does anyone have any idea where i may be able to look for a replacement door seal and soap port hose. The
machine is from about 1957 but does have its design origins from America.
I have seen the American automatic models and the workings do look the same except minor differences.
Any advise would be really helpful . Thanks Darren
