ricky5050
My 1965 bendix washer dryer has been in daily use for nearly 14 years since it was commissioned from its late start in life as many of you know .
It's only needed a new belt and timer motor.
But now I fear it may have to move along to my static collection as its developed a few faults , one of them serious. Unless you guys know how to help me fix it.
The first problem is the dryer shuts down too soon, before clothes are dry, if exiting heat is too high or heater over heats ( ie blockage or poor suction ie leak in system ) it moves main timer on a notch at a time until the machine stops even if there is still time left on the dryer timer. This is a great feature as it switches off when clothes are basically dry saving time and energy. However my machine is now doing this all the time after 10 mins so clothes are still damp. Obviously there is no blockage , or leak that I can see! I'm guessing it's a thermostat problem. I've decided this was no biggie and could use a regular tumble dryer.
However...
The second problem seems more fatal
When selecting a hot wash the heater comes on at the right time, but stays on too long until i stop it. But then sometimes it goes off too soon , again this wasn't a huge problem as I always am around when the machine is on.
But tonight , the heater on light came on and stayed on through wash rinse and spin. I wasn't sure if it was just the light , but as I unloaded it it was the heater too. The clothes were fine as the wash didn't pause long enough to overheat and the rinses cooled the clothes , but when I unloaded the clothes the drum was hot and the heater element was glowing red !
It has a strange heater arrangement , the water has to be so hot for it to heat up, ie it won't heat from stone cold , there is a heater element within the thermostat apparently !
I think the only way to remove this thermostat is to go in from back and remove drum etc which seems like a huge job!
Any one got any ideas?
I tried taking a pic of the glowing element and luckily I never leave the machine !
Thanks again
Richard
However...
Thanks again
Richard
