Best laundry detergent and/or additive for food and oil stains?
niclonnic
May 31, 2015
73
Bonney Lake, WA
I am trying to find a better solution for removing food, grease and oil stains from certain, heavily soiled articles of clothing. This includes kitchen towels, as well as my chef coat and aprons from work (dishwasher). Currently, I use All Free & Clear Plus+ combined with OxiClean powder in my GE UltraFresh FL. There are also times where, instead of OxiClean, I pour a tablespoon of dish soap onto a rag and toss it in the washer to serve as a degreaser (thanks, TikTok). But last time I used that, the dish soap left a residue in the machine; running a rinse and spin cycle afterward produces quite a bit of suds, and it's a bit tough to remove it all. This takes a few more rinse and spin cycles.
Okay, now for the reason I want to wean myself off of OxiClean. Its performance is rather unimpressive when used on kitchen towels; one particularly greasy stain was not fully removed, even after being washed in hot water. Most other food stains come out just fine. Apparently, this powder requires very hot water in order to decently remove stains. The GE's "hot" setting does NOT get the water hot enough, despite running hot water from a bathroom faucet to prime our tankless water heater. I know there's an "extra hot" setting, but it logically uses more energy and extended wash times.
So I've been looking at alternatives to OxiClean, but I'm feeling overwhelmed by the vast selection out there in the laundry universe. After lots of research, I've tentatively settled on Tide Ultra Oxi Liquid. It's supposed to be highly rated at getting out tough, set-in stains. I also thought about using Lestoil as an additive, but apparently, that stuff smells like pure gasoline.
What are some good recommendations for my situation? This can include detergent, as well as additives.
One word, Ariel! Get yourself a bag of Ariel Powdered Laundry detergent and give it a try. I’ve been using it for almost a year now and I’ve never found another modern detergent that removes oil and grease stains better! I just did the laundry this morning, two very large loads and there were several items that had stains from cooking oil and other oily/greasy stains and I did NO pretreating. I just threw them in my BOL Roper RTW4516FW2 and pressed start. The whites were washed in hot and the colors in warm and each and every item came out spotless. Plus this detergent costs way less that Tide or Persil. Give it a try you won’t be disappointed.
Eddie
https://www.amazon.com/dp/B0BJMLQ7SW
All of these options sound promising. Honestly, I'm leaning towards Ariel powder. I gave Tide Professional some thought, but it sounds a bit too heavy duty for my needs. In my household, we only use store-bought detergents, so I think Tide Pro is expensive and overkill. If it were on sale, I might give it a shot. Grease-X also sounds excessive, since no one in my family is an auto mechanic.
As for pre-treating sprays, I do own a bottle of Spray 'n Wash, but I don't use it all that often. I only pre-treat stains on my normal laundry every once in a while.
Finally, it's hard to find detergents with lipase, since I found out that P&G removed it from Tide products about a year or two ago. However, I came across Biz powder. It's an additive that DOES contain lipase, and the box boldly claims, "proven to beat Oxi Clean on tough stains like grass, sweat and chocolate!" What do you think?
https://a.co/d/dhAnTPU
First of all, Oxi Clean, while in my opinion, is useful on occasion, it is NOT a degreaser so you are wasting your money using it to remove greasy, oily stains from your laundry. Hot water is generally better for greasy soils, regardless of what everyone says about low temp washing. Also, a stain stick and/or a little Lestoil will usually do the trick. Liquid dish detergent and front loading washers do not mix - way too foamy, even in small amounts and that trick never worked for me (I use a Speed Queen traditional top loader so sudsing is less of an issue). Second, All is an OK performer at best and if your laundry is not that "stain prone", you will have decent results. However, it just isn't that strong a performer on specific stains, regardless of its label claims. I can't speak specifically to the effectiveness of store brands. Some are better than others, but are they as effective as the top rated branded products? You might have to bite the bullet and invest in some Persil liquid or Tide for those particular problem loads. To save some coin, you can continue to use All for the less stained/soiled items. Just my opinion.
Even my Tide local dry cleaners was unable to get out cooking oil stains or salad (olive) oil stains from my knitted shirts. I discovered that pre-treating the stains with Dawn Powerwash spray just before I toss it in the washer works well and doesn't generate a lot of suds, even in my soft water. I did my usual "What the hell!? I might as well try anything." approach.
I've used Dawn dish detergent on occasion rubbed a bit onto a stain, let it sit for a while to let it break down the stain, then tossed it into the washer.
It seemed to work pretty well.
I’m old enough to remember when powdered detergents did it all! You didn’t need to “pre treat” oil and grease stains, mud or grass stains. Blood stains have always required pretreating with COLD water to flush out the proteins from the fibers before washing so as to not set them. But for the most part we put the powdered detergent in our washing machines, filled them with water and let em’ do their job! We didn’t need “fragrence” additives to get out odors, the GD DETERGENT did this!
This is why I’ve been so pleased with powdered Ariel, because it performs like a laundry detergent is supposed to, without having to pretreat stains and use additional additives, save either LCB or Color Safe bleach for whites.
Eddie
It is too bad they stopped making All Powder, Circa 1974-1983. It was absolutely the very best for removing oily stains. These days I'm adding a tablespoon of TSP: Trisodium Phosphate, and a bit of borax to my greasy kitchen things. I hope that you are able to buy TSP ... Good luck
Eddie
I'd love to see how Ariel works for this task, but it doesn't seem to be available in the semi-rural area in which I live. Maybe after indoor plumbing and electricity become available here, stores will start stocking Ariel.
Eugene,
I order my Ariel from either Target or Walmart and have it delivered since they don’t carry it in my local Target. That big bag lasts us 4 to 5 months and it runs between $14 to $15. Before I was buying a large jug of Tide Ultra Heavy Duty about every 5 weeks at $15.99 a pop! That’s a substantial savings.
Eddie
Actually the current iteration of Tide Clean & Gentle powder does contain lipase. I have been using it almost exclusively for over month now it works very well at removing oily stains. And it is lot cheaper than the Tide Professional.
Tide Clean and Gentle Powder
Ingredient list
Shout aerosol is light years ahead of the bottled Spray and wash which has no solvents.
Ingredient list
Sounds like I have a strong consideration to try this powder! I've narrowed it down to either this Tide powder or Ariel.
In fact, I saw a video where this female social influencer, who does laundry as a side hustle, used Tide Clean & Gentle powder on some greasy kitchen rags; it removed ALL the grease from them. So I think I've got this laundry solution settled.
A heretic suggestion: why not adding some dishwasher powder to your normal detergent? Assuming the stuff you need to wash is not too delicate, you would get something meant exactly to dissolve grease, oil, and food, with plenty of enzymes and a good dose of alkali salts, and you can buy a cheap supermarket brand
See my post # 13.
