Blocked Eustachian tube
glamwales
Jul 17, 2006
204
Hi all
Has anyone here had a blocked eustachian tube ? I have and Im really suffering at present. I just want to comfirm symptons as I have no faith in the ENT doc I saw today.
Im off work and my quality of life sucks :( constant headache, dizziness, motion sickness, nausea, sinus pain -
can anyone here relate ?
Neil
Had that happen as a kid
They finally had to lay a drain. Same symptoms, major, seriously major pain.
In those days, removing tonsils was considered 'out'. Doctors made an exception when it happened, and happened and happened again.
Thank goodness, it hasn't happened since. Not saying that is the cause of your problem, but you are right to check around - doctors often focus on the 'diagnosis of the week'.
Hope you get better soon, I know what you're going through, it is so not fun.
Thanks Panthera - quick response.
After 6 months it's really got me down. Im getting a second opinion on Monday - I've decided to go private and get it sorted out. Apparently he is the best in Wales.
The doc today was the usual rude consultant type who didnt even introduce himself, never mind ask about my medical history !
I was an Audiology Major
A blocked eustachian tube should not cause all the symptoms you are describing. What you should mostly see is the feeling of fullness in your middle ear (vacuum otitis media) Posible fluid in the middle ear (serious otitis media) and sometimes but not always a middle ear infection caused from the above two (acute otitis media) With these there will be some hearing loss, up to about 25 db.
The middle ear where the eustachian tube is connected to is a small space which houses the three bones of the middle ear which connects the tympanic membrane to the oval window. The three bones act as an amplifier for the sound waves entering the hearing apparatius.
Balance issues (vertigo) Headache, motion sickness is not usually middle ear. This is inner ear vestibular involvement. It is possible to have a inner ear infection that can cause these symptoms, as well as other issues and syndromes. One of the most common causes of balance issues is elevated blood sugar (diabetes).
I would ask for another opinion, you may also ask for an audiometric exam, a tympanogram will tell you if there is any compliance of the tympanic membrane and thus give an idea of the middle ear health and patiency of the eustachian tube.
If inner ear, vestibular involvement is suspected your doctor could order a ENG, Electronystagmogram. This is the gold standard in testing inner ear disorders.
Below is some information I cut and pasted.
How is Eustachian tube blockage treated?
There are several maneuvers that can be done to improve Eustachian tube function. The simple act of swallowing activates the muscles in the back of the throat which help open the Eustachian tube. Chewing gum, drinking, or eating promotes swallowing. Yawning is even better because it is a stronger muscle activator. If the ears still feel full, you can try to forcibly open the Eustachian tube by taking a deep breath and blowing while pinching your nostrils and closing your mouth. When you feel a pop, you know you have succeeded. If problems persist despite trying to forcibly open the tubes, you may need to seek medical attention. If you feel dizzy performing this maneuver, then stop and discuss this with your doctor.
If you have a cold, sinus or ear infection, or suffer an allergy attack, it may be advisable to postpone a trip by airplane. Similarly, individuals with Eustachian tube problems may find such sports as scuba diving painful, and in some situations quite dangerous. Babies traveling on airplanes cannot intentionally pop their ears, but may do so if they are sucking on a bottle or pacifier. While descending on an air flight, it is best to feed your baby and not allow him to sleep.
Many air plane travelers with Eustachian tube problems use a decongestant by mouth or nasal spray an hour before take off, and, if necessary, prior to descent. The decongestant acts to shrink the membranes lining the nose and throat, allowing the ears to equalize more easily. Similarly, patients experiencing chronic daily problems with Eustachian tube dysfunction can benefit by aggressive control of allergies (antihistamines, decongestants, and prescription nasal sprays). Allergy evaluation can be helpful. In severe situations, a tube can be surgically placed through the eardrum, replacing the role of a functioning Eustachian tube to equalize the ear pressure.
Eustachian Tube Problems At A Glance
The Eustachian tube connects the middle ear space to the back of the nose.
Normally, the Eustachian tube is closed.
Partial or complete blockage of the Eustachian tube can cause popping, clicking, and ear fullness.
The Eustachian tube can become blocked from common colds or allergies.
Altitude changes can cause symptoms in persons with Eustachian tube problems.
Several maneuvers can be done to improve Eustachian tube function.
I want to add
Eustachian tube disorders rarely occur in adults to a degree that requires ventilation tubes. In most cases if this is the cause of your problems, can be treated with drugs.
Children are a whole different story. In the small structure of a childs head the eustachian tubes are almost horizontal in nature. This allows more problems with children's middle ears. Adults as they grow the tubes become more slanted and there are less chances of infection. Everyone is different so it is always best to consult a Otolayrngologist (ENT) as you have done.
I was given a steroid spray and had a ear drum pressure test and hearing test. lets hope it works
Neil
The ear drum pressure test (Typanogram) is good, what did it show? Or did they say. Normal should be a center peak on the plotter.
What about the Audiogram, did they mention a hearing loss. Normal range is zero to 10DB. If you have a blocked tube with any fluid in the middle ear you could have up to a 25db loss, or a threahold of around 35db.
Steroid spray?? Is the nasal or throat. I know there is that shift from antibiotics for ear infection, but if it has been bothering you for this long there should be at least some systemic steroids used to reduce the inflammation.
I hope you do better soon.
VITAMEATAVEGAMIN
"Hello friends!I'm your Vitameatavegamin girl!
Are you tired? Run down? Listless? Do you poop out at parties? Are you unpopular?
Well, the answer to all your problems is in this little bottle1 Viatmeatavegeamin.
Vitameatavegeamin contains vitamins,meats,vegetables and minerals> Yes,with Viatmeatavegeamin,you can spoon your way to healt! all you need to do is take just one teaspoonfull after every meal.
It's so tasty too!Just like candy!
So,why don't you join the thosands of happy,peppy people and buy a great big bottle of Vitameatavegeamin tomorrow!
That's Vita-meata-vegeamin!
LOL I just saw that episode earlier today and thought it would be funny to share.I hope you get well Vitameatavegeamin or no!
Thanks iheart
I was given a nasal spray called nasonex.
As for my results they dont say , thats one thing I hate about the NHS. Roll on monday !
Nasonex is good
I am not an MD, but I do question the usefullness in your situation. Nasonex is usually used for seasonal allergies mostly post nasal drip, and stuffiness. Inflamation of the nasopharynx can influence the eustachian tubes. Do you show any other signs, i.e. sneezing, post nasal drip, coughing?
Hopefully if you give this a week or so things will be better, if not don't hesitate to go back again, and again. There is a plethera of problems that can cause the same symptoms that a steroid will never help.
Thank God,
Neil,
Im so glad your ok, been worried sick about you with not hearing off you in absolutely ages. I know your illness has been dragging on for ages but I was worried worse had happened since.
Hope you feel better soon - thinking of you and hope you are better soon.
Hugs and love to you, Henry and Honey.
Rob and Paul
Neil, have there been any changes in your environment the past six months? This question might take some time to answer. New house, pet(s), carpeting, bed etc? Long-term symptoms like the ones you're having can be a sign of a chronic allergy.
Forcibly blowing one's nose is a major cause of blocked eustachian tubes. If one has a cold or the flu at the time, forcible nose blowing can also force infected material into the ears and cause an infection like Otitis media. For this reason I question the wisdom of holding one's nose shut and blowing with mouth closed.
To help avoid blockage and infected ears, suggest limiting strong nose blowing (sniffing it back and swallowing actually helps prevent further infection anyway). Decongestants and antihistamines can also help reduce the swelling that can block the tubes.
If the ear is infected then a course of antibiotics probably will help. But it does take time to recover from it.
I'm sorry you are having to endure this. Little children have this a lot and end up getting tubes put in their ears.
And on another note, you idiots want socialized, public government-run medicine? NO THANK YOU!!! I need the best for all my physical challenges and that doesn't show up in run of the mill environments and not being able to see specialists!!! I couldn't stomach the crap in Canada and western europe
Hi Neil,
I had that about 10 years ago, I got an infection from swimming in the Sea. The Irish Sea in my area is terribly contaminated with untreated sewage. You have my sympathy, it was terribly painful for me and the dizziness made me vomit. It took two months and several courses of Antibiotics before I got better. The Antibiotic that worked for me was called Flagil.
I hope and pray you will feel better soon.
Take care.
David
National Health Service
Hi Bob,
I don't know about the USA health system but the NHS in the UK provides free health care for all at point of use. It is by no means perfect and not without its problems but all in all I admire it. I have had nothing but positive experiences with the NHS in my area.
David
Jeff
Im convinced I am allergic to my office. It is a brand new building with no opening windows and has a large handfull of employees are suffering from various sinus, asthma and skin complaints. The term sick building syndrome has been suggested and possible air conditioning.
I also got 2 pups 6 months ago but Ive always had a dog - so I doubt it would be that.
Iheart
Other symptons include a gluey feeling in my ear ( about an inch in ) and cheek. An 'itch' that seems to come and go and a feeling of air trapped in one side of my head. I also have nasal dripping which is causing nausea and some morning sickness. :(
im 27 going on 72.
Neil, then the first step is take a few weeks off work, go somewhere dry and hot and see if your symptoms decrease or disappear altogether. Especially in a new building, the list of possible allergens is longer than your, er, arm.
Even with its limitations, the NHS
provides the folks in the UK with an enormously better health care system than the US offers it's taxpayers.
A truly 'socialist' system, by the by, would not permit private practices...tho' yes, the British system has many failings related to the structure. Still, it says something when every German medical student I tutor tries hard to do their second practical year in the UK. I've visited graduates in Manchester, they've shown me their teaching hospitals. If, may the gods forbid, I should suddenly fall ill on the street and my survival, not to mention future good health depended on the ability, care and facility of the emergency room personnel...well, I'd take a big city or a hamlet or a rural county hospital in the UK over the US, anytime.
Actually, after the way my parents (who have money, social standing, insurance) were treated in the emergency room in Fort Collins, I think I'd take a hut in the Stepps of Mongolia over the US system at the present moment. No matter how good the nurses and doctors are, your current system does not work.
Period.
Calling all Western European systems socialist and of poor quality is, however, just plain wrong. Bob, why don't you do some independent research - your comments on this and other related topics tell me that you are only getting information from people who cherry-pick at best and outright lie at worst.
