Blow dryers: 1974-84 :)
cfz2882
Feb 9, 2010
2,689
Belle Fourche,SD
not terribly interested in these as an adult,but was quite interested when I was ~8-10 :laBelles store had some realy nice ones in 1978 :)Mostly made in Japan/Taiwan/HongKong during this era,but a few were US made.Axial fans,Transflow blowers and centrifugal paddle fans providing the airflow.1974-84 seems to be the prime era for these hair dryers and I have about 20 of that era.
Back in the 80's when I had a full head of hair, my go-to was always the Conair Pro 1250. It was very well made and I used to get quite a lot of use out of them before the cords failed at the strain relief. Not knowing fully how to fix things yet I would toss it after several years and buy another. Then they stopped making it in white and the last one I bought was a see through brown one. They were very smooth running and blew massive amounts of hair.
Not really interested in hair dryers either, but there was one model in the past that I somehow found looking great. It was an old Moulinex. Only 400 Watts, so rather anemic. But I guess it was the classic design and the two buttons that I liked.
I never use a hair dryer, except for defrosting the freezer once a year.
Still using my BD from the early 70's. It's a Norelco 1200-2.  Switch went bad  few years in, took it in for repairs -still has the sticker from the repair shop on the handle.  Many years later the cord went bad so I replaced that.  Still use it often, works fine and I still have the hair to need it especially with covid hair- 6/m and counting since last trim.
I worked as a Cosmetologist from ‘70 thru ‘85, and also worked as a Telephone Operator from mid’76 thru late ‘78, while still doing haircuts and perms at home for my special customers, and then worked for the last 6 mo. of ’79 for Hewlett Packard as a micro electronic assembler, again still doing haircuts at home.
In ‘74 when blow drying was really starting to come in here in Northern California I bought this 1500 watt Pearl Duck blow dryer by Dubl Duck.  In ‘80 I dropped it and cracked the casing on the nozzle, hence the duck tape.  But it didn’t hurt the runnin’ of it none.
This dryer earned my bread and butter from ‘74 thru ‘85 when I finally left the hair business for good to work full time in the Human Services Dept.  This dryer is still in excellent functioning condition.  Its quiet and very powerful, both attributes that were essential when working professionally cutting and blowdrying hair.  Time is money!
Now I only use it to dry spills on my clothing.  I haven’t blown dry my hair for over 30 years now.  I have cut my own hair since I was 12 and still do.  I seldom even use a comb.  I still have a full head of thick, slightly wavy almost all white hair that I comb with my hands and fingers.
Eddie
I still have my Sunbeam 1000 var-i-matic that I got for Christmas sometime between 1973 and 1975. My oldest sister was glad I still have it when she was here 4 years ago helping me recover from surgery.
used to have a "Max for Men" blow dryer...in fact still do, but its a Norelco now...I liked the wide nozzle area for using a brush....
but since my hairline has made a beeline for my behind.....have no need for a blow dryer outside of drying my chest hair....
I do recall our scout leader demonstrating how to use a blow dryer on our undercarriage to prevent jock fungus/itch after swim lessons...
actually I dont miss the days of shampooing, conditioning, wash/rinse/repeat, curling irons, gels, hairsprays, mousse, antlers coming out of the moose, looking like Bullwinkle!....one hair out of place, and you had to start all over.....
those were the days!
I blew dry my hair for a few years until I discovered punk in '80 or '81. A bit of hair gel and finessing and I was good to go.
I dabbled with perms in the mid-80's in an attempt to tame cowlicks. After a few years I gave up and went to the flattop I've had since.
Then all the gels started causing my skin to break out so I skipped that and went shorter.
Now I have the Covid Cut I do myself: Basic buzz cut with an attempt to flatten the top a bit
I don`t need a blow dryer for my hairstyle but I`d catch a cold all the time if I don`t use one. Even if my hair is very short or in high summer heat I couldn`t live without one.
At the moment I have three.
My daily driver the BaByliss is a professionell one, well it`s a low end professional brand, but I like it.
Then of course I need a small dual voltage one for traveling just in case if cheap quarters don`t provide a hair dryer.
The old one is a flea market find I couldn`t resist. Its a bit scary even though I rewired it with a grounded cord. Don`t use it but it still runs flawlessly.
This discussion led me to check eBay for Gillette Supermax2 Adjustable.  As sometimes happens, there was one touted as NIB.
The brush attachment (on the accessory handle) with hair and gunkus on it has obviously been used but appears the rest of it has not, including the cord still wrapped.
It runs OK, on a short test thus far.
The first mens hair dryer that I recall being marketed on TV was in the late 60's or 1970 ish. THe Hot Comb by Gillette which looked much like that style Supermax pictured above. Up to that point, a man using a hair dryer was considered somewhat effete. The design of the dryer itself, not looking femininee along with the bevy of great looking guys and the advent of "The Dry Look" a mens hairspray quelled a lot of that and soon the market was flooded by copy cats
I couldn't remember what brand my first blow dryer was until I saw the one above - it was a Gillette Promax Compact. I got it sometime in the mid 70's for Christmas. After that I had a Conair for several years. Next was a Revlon that took an unfortunate swim in the toilet, so was discarded. I now have another Conair that's a jadite green color.
I use the dryer almost every time I wash my hair, as it takes too long otherwise. My hair is rather thick, and is shoulder length at this time, but planning on getting it trimmed in the next couple weeks, as I'm starting to look like a member of a rock group.
yeah, I remember those, like the Max for Men hatchet style...somewhat more manly....
versus the pistol grip for women.....
more or less a selling point....any yet, just realizing I have a heat gun out in the garage.....oh well, either one will help defrost the freezer!
much like Remington/Norelco having the electric razors.....black for men, pink for women(Lady Schick)....just a copy cat to appeal for both sexes...
amazing how manufacturers could sell you on anything......Dove beauty bar for women, Irish Spring soap because its Manly....my goodness, we would believe anything!
It`s interesting you mention Irish Spring as "manly" because decades ago when the German equivalent Irischer Frühling was still on the market it was rather marketed as a unisex family brand.
It`s funny how we get brainwashed by advertising, isn`t it?
I`m surprised only few American men seem to use a hair dryer on a regular basis as using one might be considered effeminate. Do American barber shops send their customers out in the cold with wet hair?
Over here they`d use the "normal" pistol shaped ones.
One time I had a hair cut in the States, but it was only a dry cut and I haven`t paid attention if hair dryers were used on other customers.
I also think emancipation should go both ways. Fight for your basic rights if you still live in an intolerant society that denies you a hair dryer ;-)
I know were jumping topic, but are we buying stuff for the product, or for the person in the commercial?
love these Dr. Squatch commercials.....
Mike is handsome....
Re: Replies #13 and 14
Those Gillette Pro Max dryers were sold more as something that was easier to handle than a professional “pistol grip” blow dryer.  They made these both for men and women.  The average consumer could visualize using a dryer that more resembled using a brush or a comb and maintain some control over their hair, keeping it from blowing all over the place.  However, these dryers were slow, and never achieved the same results and volume that a so called effeminate pistol grip dryer did.
So these dryers didn’t stay on the market for long.  I bought one of these in about ‘72 when they first came out for home use.  What a useless piece of junk it was. As blow drying  hair became common place with both men and women we all learned to use the professional type of blow dryers by watching them being used by the professionals that cut our hair and by practicing.
I cut hair professionally from ‘70 to ‘85 for both men and women, straight and gay and I never once had any male customer turn down having his wet, freshly cut hair being blown dry because he feared his masculinity being questioned.
Eddie
back to blow dryers
My General Electric Blow Dryer can't compete with Dr. Squatch commercials, ha. (BTW, There are many more Dr. Squatch commercials online that are just hilarious!)
I have quite a few GE blow dryers here are two of them, one in box one out. I really like them. Got a good rating from Consumer Reports, except CU found the color coded speed/temp controls somewhat confusing.) There are many options of color combinations to give various temp/speed pairings.
I bought my first GE blow dryer in 1976. Even back then, GE was making them in China.
" we would believe anything! "
The fact Detroit pushed the Aztec, Cimmaron as a Cadillac, and the Granada as a Mercedes 450SE proved long ago just how the public here falls for it and still does.
Dr. Squatch....
Great soap but prob the poorest value out there as far as soaps go. The bars are thin and tiny. I put in 4 orders then finally gave up once I added up that their soap would have cost me $300.00+ per year after each bar only lasted 2 weeks tops. My favorite was the Pine Tar. It smelled great and left me feeling fresh. Problem was the bar disintegrated just looking at it. I had my doubts when I left it on the shelf in the shower and the water spray hit it directly and it made a strong black wash of water down the wall. If I left it like that for an hour I bet the bar would have been 100% dissolved. If they either made their bars twice the size or cut prices in half it would be a much better deal. I went with Shea Moisture and also the all natural African soap that comes in a huge block from Ghana I bought off Amazon, both bars are classified as black African natural soap. They moisturize better and smell great as well.
If you want your bar soap to last longer let age for at least several weeks before using it.  When you get it home remove the outer plastic wrapping from multiple bar packs and store it in a dry place.  The linen closet is a good place for storing bar soap while it ages and dries out as the scent of the soap will also scent your linens.
This is especially important with Ivory Soap.  Its so soft when its freshly out of the wrapper that I can almost put my index finger right through the center of a bar.  But after several weeks of allowing it to dry out its hard and solid and doesn't disintegrate right before my eyes when it gets wet.
I age all bar soaps and I get several weeks out of a bar of Zest that is left on a soap holder in the shower.
Eddie
Several things
My husband Bruce makes basic, old fashioned lye soap, and it washes away pretty quickly no matter how long it has aged, but it is wonderful, so mild that I feel fine about washing my face with it.
Handy Hannah
This thread brought me back to Winters in the 1980's as a kid.
Growing up we had a wood burning fireplace in the living room and it was the primary source of heat.... we also had central air heating that ran off propane from one of those big giant tanks in the yard (lived out in the country) but the fireplace heat was free, only cost the manual labor of harvesting firewood, and we did what we could to get by.
So the thing had to stay burning constantly in the cold months, it stayed well stoked during the day and evening but you could only do so much at night. In the early morning, if you were lucky and it had been stoked here and there when someone got up in the night to pee or somthing, there was still a coal bed smoldering.. so out came this ancient hair dryer to blow the coals and bring them back to life to catch the fresh kindling on fire.
It sounds crazy but it did the job nicely, basically an electric bellows to spark up the coals. Dad was a junker and found it who knows where, the fact it was metal and not the more modern plastic kind made it suited to the job and we even had a stand for it... the wooden handle is a hollow dowel so somewhere my Mom dug out this base to an old plant stand or a paper towel holder or something that once the original attachment was removed left this threaded peg on the wooden base that the dryer fit right in so it could stand upright unsupported.
These pictures aren't mine but it's the same model, made in the 1950's I believe, the body is metal, the handle wooden and those toggle switches and the tooled vents on the side make it look like a Ray Gun right out of a 1950's Sci Fi movie.
One of my aunts had a Handy Hannah hairdryer.  She would place it on a table behind her then set in front of it with her hair in pin curls and move her head when it got too hot allowing the hot air to dry all of her pin curls by moving her head like this until all of her hair was dry.
Later on she got one of the new Lady Sunbeam hairdryers with the plastic hood attached to a hose connected to the hair dryer.
Eddie
My mom and Aunt had a beauty shop way back in the early '40s.  I still have one of  the all metal bee hive style dryers tucked in an attic. Used to play with it as a kid.  If I recall I think she told me they used the old electric rod setup to do perms, but that is a hazy memory.
