Blue box mod1
I'm gonna guess
On 2 of my machines, I added switches to a) stop the timer motor and allow extra time anywhere in a cycle, and b) override the water level sensor to allow me to suck suds back up from the drain tub during agitation.
You've added a switch on top of the main console, and another one at the right side, maybe same 2 ideas as me?
my guess
The switch on the side of the console is for shutting off the suds valve so the wash water isn't saved every time. Not sure what the other switch is for.
1/2
For MOD1 I added 2 switches. One is the toggle switch on the side. The other switch is on the console. This is not a suds saver machine, and I did not add a suds valve or modify the plumbing. Also the switch on the side does not stop current to the timer. So now, what type of switch in on the console? Think cosmetic.  OOOOOOOOO!! First time I've used the editing bar!!  Also, what was special about the TOL model of this machine when it comes to looks?  Here is a hint:
cfz2882 has it nailed! The photoelectric switch on the console is for the Metal Halide lamp. The toggle switch on the side bypasses the photoelectric switch, as the original light was shut off by the timer. The purpose of the MH lamp is for a tub light. The work light is the 3rd part of this mod. Lets go through the 1st part of the mod.
I could have used a florescent light for this mod, but that would have been too easy. MH lamps get hot, so they need some space. They can also explode when coming it to contact with water. Such an explosion can cause someone to have a bad day. I have to a vapor tight fixture, clearances in the cabinet are tight, so it has to be mounted to the top of the machine.
The cabinet had to be modified too. What this picture does not show is the additional cutting I had to do to the right rear gusset bracket later.
Here is the ballast kit. I'm going to be very vague for the wiring side, as I don't want future viewers who know nothing about electric to attempt this.
