Boil wash on stove?
lordkenmore
Nov 13, 2009
4,069
The Laundry Room
It seems to me that I've read here of people doing a boil-type wash in a big pot on the stove. Am I right in remembering this? And are there any sort of general guidelines of how to do it?
Thanks in advance for any ideas!
Have a vintage French "laveuse" which for a better description is a boiling pot that showers contents with water, rather than merely letting them sit. However have simply boiled items in a stock pot before.
One thing to remember one normally boils laundry that is already clean or at least pre-washed. In old days, wash was soaked, rubbed/scrubbed, rinsed, then put into soapy water to boil. This was done to mainly get rid of any remaining soils without harsh rubbing. Also boiling would release soap from textiles so the subsequent hot or warm rinses could carry it and any soils away.
Later, when sodium perborate came upon the scene, boiling was done to whiten and sanitise laundry.
The only time soiled linen is put into a boiling pot was when it was known to be infested with vermin (lice, bed bugs, fleas....), or was used by a person with an infectous disease. Think of Mammy asking for Mr. Kennedy's pants (that had lice) so she could put them into the "berling" pot.
That being said, if you want to boil laundry on a stove top find yourself a good deep stock pot. Fill partially with warm water, then add whatever detergent, soap and so forth you are going to use, then stir until dissloved. Add laundry then fill with more water to cover at least about 1 inch over the top of laundry.
Next simply turn on the fire and wait for things to happen. As the water heats it will expand and laundry will start to float up, you will need a long wooden spoon or something to act as a "laundry stick" to push things down and give them a stir.
*WARNING* If you are using oxygen bleach or a product containing same, as the water heats the hydrogen peroxide will start to release oxygen and foaming leading to "boiling over" of wash water. Keep an eye on things and lower flame accordingly.
Boiling really shouldn't take place longer than ten minutes, fifteen at the most, after that you run the risk of damaging the textile's fibers. If you are using the proper dosage of oxygen bleach and or detergent this amount of time is plenty.
Once finished boiling either use your laundry stick or a pair of tongs to transfer the wash (use caution, VERY hot) to a sink or another vessel to either rinse, or carry to washing machine if rinsing will take place there.
It is possible to simply carry the stock pot full of water and dump the lot in the sink, like when cooking pasta. However if the pot is heavy and water very hot, you are looking at an invitation for serious burns or injury.
After boiling best to rinse items at first in hot or at least warm water for the first few rinses. You want to bring down the temperature gradually to prevent shocking the fabric and causing creases.
From what I remember you must first soak the laundry for several hours in cold water with sodium carbonate before boiling to prevent setting of protein based stains. Then put the laundry in a laundry pan (looked like an ordinary pan but much bigger), add detergent and place it on the fire. The pan had a perforated insert on the bottom to prevent the laundry from direct contact with the hot bottom. Besides some occasional stirring nothing had to be done while the pan was on the fire. The process filled the whole house with a typical odour that I will always associate with wash day.
Don't boil elastics as found in socks and underwear.
I say prewash and spin FIRST.
Then soak (optional, to me........)
Boil wash (retrive clothing articles with tongs!)
Spin in washer
Wasn and rinse, as normal, in automatic washer.
Haus-Frau? Me?
I only boil-wash once or twice a year...........
The use of phosphates religiously (yes, it brings me to my knees, it's so effective) keeps my whites sparking and elegible to win any '1950's Housewife-of-the-Year' award!
Those small washers sold in the 40s and 50s with the motor mounted in the top were often used on the stove top when washing diapers. I don't mean that the motor was going while the water was heating, but the vessel was able to take direct heat. Keeping up or trying to keep up with diapers in apartments was one of the main reasons people bought these little machines.
During the 40's, 50's until mid 60's my mother met with my grandmother and aunts twice a year at a laudray that had the old square Maytag wringer wahsers that had live stream pipe into them and did the whole house laundry. This was usually in spring and fall. They brought everything washable to boil wash to clean and kill germs they said. I can still close my eyes and hear the groans and rumbles from those machines. They frist would fill the washer and the frist rinse tub. All the clothes were pre rinsed in the wash tub and run through the wringer of couse all were sorted. Then they started the washer with steam and put in the first load. They reused the wash water at least 3 or ore times before emptying and starting with fresh water. For bleach they did it in the first rinse then on to the second and then the third with bluing if needed. All wrung out and in baskets they would take home to hang out on clothes line. In the mid 50's the laundry did add a big spinner to get more water out and then 2 steam heated dryers. My older brother and sister said they remember that also. Was a good time with all of us kids together playing. All the women had either wringer washers and later automatics at home. My mother was the last to give up her wringer washer in 1964 for a Maytag A700 and the Auto matching Dryer. After using the dryer for 2 weeks she had my dad take the clothes line down never to hang clothes again.
Glad to see this thread, as I thought Granny was the only one who did this. She would boil EVERYTHING in the spring; then hang them out to dry. I can still remember the smell of the towels ... wonderful!
Rob.
"Fare il bucato " = faire le linge / to do laundry/
Thanks to Mielelabor it comes up an obscure meaning of an italian word (even to italians too). "Laundry room" translates into "lavanderia" but "laundry"/"linge"/"waesche" translates into "bucato". Literally "bucato" in italian is an adjective that means "perforated", e.g. "the strainer is perforated" turns into "il colapasta è bucato" or "il colapasta è perforato"
One could that italian frontloaders look somewhat that chicken washer and have nails instead of holes in the drums ;-)
Actually this word that apparently has nothing to do with laundry was due to that very "pasta strainer insert" in the boilwash pot shown in Mielelabor's shot
The "cycle" started on the river bank with some washboards and a lot of elbow grease. Then laundry went in that strainers, with a pillowcase filled with some soda ash on the top. Then some hot water was poured over the "soda ash bag" and all the stuff sat "brewing" that way for several hours. Next step was the boilwash big pot. Those pots were as big as those used in dairies. Some of them had a central "tower" like a moka coffee pot, to enhance convective movements of boiling water. IIRC Launderess' one has this design.
In a town round here (Pavia) there is a monument to the launderess. This job was still common till WWII here.
No need to say that in late 50s when frontloaders started getting popular this job quickly disappeared
