A few weeks ago I looked at a Bosch DW for a friend, that one was completely dead and had an obvious blown up chip on the main board, the board was $388 so the machine was replaced with a new F&P dishwasher. I have the dead one in my shed.
Now another friend has asked me to look at their Bosch dishwasher, a similar model but a few less features. Both approx 10 years old. The second one is a Bosch SMU50E15AU. I assume the AU on the end just means Australian market. This one tries to work, it does an initial pump out, then at fill stage it doesn't fill. It is NOT the fill solenoid, I have checked that and it is OK. I believe it is a main board fault again. This board is $420 but I have the other machine's board to pinch components from, it is almost identical but not quite. I'd like to try to get this one working by swapping components from the other board, but I can't find any obviously faulty components. It is mostly SMD devices so this will test my soldering ability.
First up, I'd really like a repair manual for this SMU50E15 dishwasher, can't find one online. Does anyone have a link to a suitable manual for this model or something similar? 10 years old, Bosch, made in Germany.
So far... the solenoid is 240 V AC and there are tracks on the board for both Active and Neutral 240VAC, not through the switchmode power supply. These appear to be all OK - I can measure continuity to the switching triacs for all the solenoids, which are on the neutral side. The Active side - feed to the solenoids leaves the main board, goes to the flood float switch in the base, then back to the board, then out to the solenoid, the solenoid neutral is switched by a triac. All this circuit tests OK from AC Line in (Active) through float switch, solenoid to the triac. So it appears either the triac is faulty (not switching on) or not being switched - the microprocessor switches it through a transistor and a couple of resistors. The transistor may also be faulty, the resistors test OK. There are several identical circuits, one for each solenoid, and they all check out the same when I check the components resistance from terminal to terminal with a multimeter. So unless I'm missing something, either a transistor or triac (that physically looks OK and tests the same as its neighbours with simple resistance tests terminal to terminal) is faulty, or the microprocessor is kaput.
The other possibility is some sensor is detecting a fault and so the processsor is not commanding a fill - but that appears unlikely, as the machine sits and waits for a fill, then appears to time out and goes to "end" and displays a "check water" light. It doesn't have any useful display, just an "active" LED during operation, plus LEDs for End, Check Water and Rinse Aid.
I've tried manually filling it with a bucket - it washes for a few seconds, then stops and pumps out. It is a 3 phase combined pump with inbuilt single phase heater, pump turns a few seconds, heater tests OK but never turns on. I have a spare from the first machine, they are the same. I haven't tried fitting the spare pump yet - there are 3 sets of connections to the pump/heater unit: for pump motor - 3 purple wires; for heater - 2 heavy red wires; and for something else, maybe temp sensor or tacho? - 3 grey wires. Could a fault in the 3 grey wires cause this fault? Any other suggestions?
The First machine, the dead one, after I said I couldn't fix it, the owners phoned around to get someone else to look at it. Every repairer they tried said pretty much the same- they wouldn't even look at a Bosch. Just throw it away. Online reviews of the later one, that I'm still trying to resurrect, are poor, with many reports of "check water fault, it was the main board at a cost of over $400." So I suspect I'm wasting time on this but if swapping over a triac or transistor can fix it, I could do that. It some sensor is stopping the processor from trying to fill, I probably have a spare on the other machine.
OK folks, what can you add? Anyone have a link to a service manual for this machine or something similar?
Oh, it's awful to work on, too. So cramped underneath, you have to lift off the whole wash compartment to get at the pump for example. Eeek.
