rolls_rapide
You're very welcome!
When I was researching washing machines a few months ago, I came across the Which? article about washing machines not achieving temperature.
Speaking of temperatures, apparently my Panasonic's "Autocare/Econavi" sensor programme selects the temperature itself, between 30 deg C and 43 deg C. It seems to depend on the detergent sensed by the optics: powders seem to get the 43 deg C treatment; liquids less so.
I've been observing what the machine does on the sensor programme with different loads. A smallish load of polycotton sheets got the pretty standard "1h 18mins".
The next load, run immediately after the first, was a pair of jeans, Craghopper trousers, a few t-shirts, several pairs of underpants. And the load was calculated to take... 2hrs 45mins! (I just about fell through the floor...!)
Needless to say, I thought that a tad too long for such a small, relatively clean load, so I let it wash for about half an hour, then cancelled the programme and set it to the Cottons rinse & spin @1600 rpm. It must have been in perfect balance, because the jeans have never felt drier - I was most impressed.
Similarly, today I washed (on sensor prog again, with a crushed detergent tablet): a white bath towel, a hand towel, a white cotton t-shirt, and a couple of pairs of socks. The machine started at "1hr 18" then switched to "1hr 32". Near the end of the wash phase, I touched the door glass, and it definitely felt hotter than 40 deg C.
However, the interim spins did not take place, due to out-of-balance detection. Instead, simple 'fill-tumble-drain' rinses were done. The final spin was aborted umpteen times by the machine. Eventually, after twenty minutes of trying, it reset the spin programme itself, and span very noisily for a few seconds to get most of the water out. More tumbles, then FINALLY ramped to the sensor programme's maximum of 1400 rpm.
Spin cycles seems to take up to 30 minutes, if out of balance. Running the machine empty on the same programme, reveals that the spin timer hops and skips down quite rapidly: 11 mins turns out to be more like 8mins.
The joys of modern technology!
