Brain Dead Unimatic
lebron
Mar 26, 2009
887
Minnesota
If a Unimatic is acting like it isnt plugged in (meaning absolutely no activity), where would one start to look for a problem? Any tips on how to use my voltmeter on this thing while its plugged in w/out zapping myself? Also does anyone know where common shorts may be.
Glad I opened this post. I thought it was a slur against Robert.
Any broken wire in the circuit, since it is such a simple wiring path, will make the machine seem dead. When we found my 58 washer, it was a matter of a wire having come off a terminal on the motor. If all of the wires are connected properly, you are going to have to check each wire for continuity which is done with a battery-operated multi-tester so there is no danger of shock. The first wires I would test are the ones most subject to vibration like from the timer to the motor.
It could be a short in the timer. I remember Greg having the same issue with one of his unimatics in Omaha when I attended his wash-in.
Bypassed the console circuit breaker, still dead. Preliminary inspection of wiring yields nothing. Going to try Tom's advice now
