The agitation also doesn't disturb the water surface that much, so it doesn't create foam and the gentle swirling pops the bubbles. When you start the washer, the fill jet will create a world of suds, but then, during the wash the foam disappears, it's actually boring. (anyway, foam doesn't clean)
I can't imagine this washer causing suds lock if used following the cycles on the timer. Maybe if I put a whole box of detergent and force spin while it is still full of water.
Also, the gap between the drum and the bottom of the tub is huge (you start filling the washer and it takes forever to reach the drum), so there is more-than-enough space to spin without the water reaching the bottom of the drum, even with a slow pump.
