Brutal Cold Invades USA
toggleswitch2
May 23, 2008
5,000
BRRRRRRRRRRRRRRRR. this morning just outside of NYC
2*F (-15*C)
Link is about winter weather coast to coast by AOL. (link may change over time).
Many of our heating systems are designed (sized) for a min. temp in the teens, so they are struggling to keep up!
I guess I'm one of the lucky ones. My furnace is oversized - 175,000 BTU's - and was put in when this house was poorly sealed and uninsulated. On cold winter nights it would run continuously. But after I sealed up all the major air leaks and most of the minor ones, and put in 12" or more of insulation in the attic, it runs a lot less - so much less that I've thought of replacing it with a smaller one that might be more efficient.
While it's been chilly here, it hasn't been cold enough for my neighbor's cherry tree to drop all it leaves yet, and the magnolia in the front yard is flowering... as it loses its leaves... Go figure! The lowest my backyard thermometer shows, so far, is about 28F (it has a telltale pointer).
For the first time ever I've rigged up some plastic sheeting as a kind of roof over the sweet and hot peppers in the garden. I'm hoping to keep the plants alive until spring and then give them a jump start on the growing season.
Time will tell.
The weather reports from the midwest are chilling: 30 below... yikes!
12F here right now
I have NO desire to do the conversion to Celsius.
However, it's supposed to be in the mid 40s here by Wednesday.
Unlike years past, the furnace has been running well, so far.
Lawrence/Maytagbear
Lawrence, glad the landlord has turned on the furnace and you're keeping warm. It's 34 here now, was down to 23 last week with the previous artic blast and we had some icy roads too. The heat pump is keeping me warm at a set of 70 degrees.
It has been lower already on previous blasts. There were very light snow flurries a couple weeks ago, just a teaser. 36°F last night, with tonight forecast 39°F and warming next few days. Fri & Sat forecast a high of 78°F!
Did I say my furnace is 175,000 BTU's? I must have been thinking it's 100,000 BTU's at 75% efficiency... more like it. Still too big for the 1650 sq ft here. But at least it can get the house as toasty as my finances will allow.
I turn the thermostat down to 60F overnight, so I'm familiar with Toggles' reluctance to get out of bed before it cycles back on in the morning to a blistering 66F. I've invested in a bunch of thick faux chamois shirts and they do the trick indoors at that temp. Also are good for working on the outside of the buildings or on the garden during the daytime. Cheaper than keeping the place 72F.
-15 degrees with a wind chill reading of -40 here in southwestern Minnesota last night.
Despite that, I ventured out to see friends who live 30 miles away. Had been housebound Sat-Sun due to a blizzard. Anyhoo, it was so cold that my driver's side door wouldn't latch shut. Had to hold it closed all the way home.
Ah, Minnesota.
Bitter cold here. 0 Degrees and windy. Before that we got an ice storm! Sucks! Many people without power, and then this cold snap. I am lucky! My electric service is fine,even though some tree limbs broke off in the back yard.
The boyz are staying here, since they have no electrical power. It may be after xmas before the power lines are repaired. Frozen pipes anyone????
Lawrence, I'm no converting tem. I'm cheating by ref
~Anyhoo, it was so cold that my driver's side door wouldn't latch shut. Had to hold it closed all the way home. Ah, Minnesota.
Is it true that your parking meters there offer electricity to enable the plugging-in of everyone's crankase/oil heater?
Hi Rick. IIRC in your case you have gravity hot-air as heat so all it takes is two 12v (car) batteries in series or four 6v (lantern) batteries, again in series, to crank open those gas solenoids in a black-out! With a double-pole double- throw switch one could have power to the solenoid be selectable from the transsfomer or batteries as the source.
My supplemental eletric heater finally got the place up from 64*F to 70*F (22*C) in 5 hours. LOL In theory the landlord provides heat, but the superintendent has not figured out yet that the HeaTimer brand control system needs to be tweaked to input (on a dial) the actual outdoor temp every few days.
The timed heating cycle has remained the same for days of 0*F to 50*F and logic tells us ya need more heat in when it's colder out! BRRRRRRRRRRRRRR
STAY WARM EVERYONE!
It's summer south of the equator (I don't mean the brand of wahers........) isn't it? LOL
Plug-In Parking Meters: I've never seen or heard of such a device, Togs, but it would be a great idea. I had crankcase heaters on all my cars, barring the present vehicle, which is a 1994 Geo Prizm (re-badged Toyota Corolla). It has 225,000 miles on it and has never failed to start in the winter.
I recall a couple of winters ago it got down to -29 here, and when I depressed the clutch to start it after work, it took a full 15 seconds for it to return to the disengaged position. Now, that's cold!
Hope you're staying warm, Togs!
brrrrrr
Right now its 11 degrees and yesterday with wind chill it 40 below. I have an old house with very little insulation, old windows most are covered with plastic. The second floor doesn't get much heat at all. I can hear the furnace running but very little heat comes out of the registers. I don't mind it cool up there, I can't sleep in a hot room. I have a heavy blanket with a electric blank I keep the blanket at either 5 or 6, the dogs and cats love it. I have an electric space heater in the living room that helps take the chill off a little. I also have one in the kitchen been concerned about the pipes freezing. I plugged in the heat tape the other day, and it went pop, and the lights went out. I don't like those things anyway.
Summer here for sure
Hi Steve,
The pics that everyone is posting are amazing, I hope you're all staying warm.
As we approach Christmas here in Queensland, we have highs of around 35degC and Lows of 17degC (95degF and 63degF respectively) The southern states here have been cool the last few weeks, with lows below 10degC and highs in the mid 20's degC.
Its been a couple of weeks since its rained so the humidity is still nice and low and hopefully it'll stay that way until after Christmas.
There are few places in Australia that generate that kind of snowfall and most of them are a long way above sea level.
