Bug Report #15 - Select -o- Dial Updates
Unimatic1140
Administrator
Staff member
Apr 26, 2001
10,130
Minneapolis
I've made another change in an attempt to speed up some of the longer threads. The Select-o-Dial drop down menu worked really slick for those of us with newer, higher memory computers. On older computers all the memory usage that the drop down menu was using was causing some longer threads to slow to a crawl.
I'm experimenting with changing the drop down menu to simple icons. I've also changed the Information Bar above each post so that if it is a post you made, it will be in a lavender-ish color to make you own posts stand out in longer threads.
Here is what I need to know...
#1 When you hover over the Edit/Remove Post icons (on posts you created) if you keep the mouse over the icon for at least one second can you see the roll-over text pop up?
#2 For those of you who had some of the longer posts slow down, does this speed up the loading any?
Thanks everyone, ever upwards and onwards!
Yes Robert
It pops right up and I can see everything; and I do not notice any speed issues.
Also you may have explained this but I assume everybody's own bar is now pink... just noticed this
Actually Jed its Lavendar :-)
I did this to make it easier for everyone to be able to pick out their own posts when reading long threads.
Feature Request
I read the site from both home and work. So lots of threads in one place or the other never progress past the "wash" label. I'd like a command to "mark all as read" (set "spin") so I can see from the less-used browser which ones are still active and which ones are static. Threads which are still active transition to "rinse" when someone posts in them.
Hi Todd,
That's not a bad idea actually, although one can now do nearly the same thing by clicking on the thread and immediately backing out.
Another feature I thought at some point would be nice to have is a "Mark as Uninteresting" so the thread would still pop in the index list, but would be in a light gray, so its easier to ignore. Clearly all of us here see occasional threads that are of great interest to some members, but not necessary to ourselves.
I don't get hover text on the control icons, but the associated function appears to be accessible if the icon is clicked.  I don't have any posts new enough to allow editing or deleting (well, except this one now) but the "Report Offensive Post" function is accessible on the rest of them.
Firefox 3.6.8 on Win2K Pro.
David, 6 years is not excessively old.  I use a PC at work that's 12 years old.   :-)
Thank you Glenn! Question, can you see the hover text on icons where you are allowed to edit or remove your post because less than 6 hours has passed????
Also...
Can you and/or anyone else who cannot see the rollover/hover text here in the Discuss-o-Mat check out this site. On the upper left hand of the page are three icons with hover-text (see the red circle in the image below). Can you see the hover-text on this site?? Thanks everyone in advance!
Robert, I don't see the hover text on my new post above, or at the refrigeration site.  Looking at the source code on both sites, images are coded with both alt and title tags, so it's apparently something quirky with Firefox on my Win2K, IE6 hover text works.  The same Firefox version on XP, hover text works.  Sorry, I shouldn't have said anything about it, I recall the same thing happening when you were working previously on the control icons.
No I appreciate your help Glenn, I am glad you said something as this is good for me to know. So now the question still remains, who else cannot see the rollover text?
It seems to be working for me on the post I created over in the As the Tub Turns forum. I get the hover text on edit and remove. I went to the post Quality Ranges in this forum and though no new posts there, when I clicked Spin it dropped right to the bottom. That post, due to the pictures in it was loading a bit slowly in the past.
I am seeing it
Robert
Using an 8yr old HP, 1.6P4 Processor and, apparently 894mb RAM. I am seeing the Rollover text with no problems and I too tried Quality Ranges #1 thread and yes, it seemed to be noticeably quicker. Noticed the lavender bar last night too.
I like the idea of "Mark as Uninteresting" too.
As ever, many thanks
Al
This is an edit: Whilst I could see the rollover text before my posts were too old for editing, removal. Tried again with the above post and all fine - editing and removal are both there
Testing for hovering text...
MacOS 10.6.4:
Firefox 3.6.7 yes
Safari 5.0.1 yes
MacOS 10.4.11:
Safari 4.0.5 yes
Firefox 3.5.9 yes
MacOS 9.2.2:
iCab 3.0.5 (PPC) no
So it works for me, except when using the old mac. I don't notice a difference in download speed.
Noticed something else when using iCab: when I use the "Update & Preview" button, I sometimes get the message: "Network Error #-3159". Not a big problem beause I use iCab only for testing the new AW features :)[this post was last edited: 8/5/2010-03:33]
Just to report for the record ... I don't see roll-over text on Firefox 2.0.0.20 on a 12-year-old dual Pentium II 333Mhz running Windows NT 4 Workstation SP6a.
I can see the text, and today when I went into the Bear thread, I clicked on Down to Last and zip I was at the end, yesterday it took a long time to get to the end of the thread, don't know if this was a computer issue on my end or what.
Robert your are doing a great job, THANK YOU. :-)
Thanks everyone!
I do think that not using a drop down menu formatted different for each and every post speeds the loading of the text portions of the pages so you can pop down to the bottom while the images are still waiting to load.
I guess I really cannot be too concerned with 12+ year old computers, but maybe I can change the graphics to be more obvious.
I suspect this is why the google.com interface is so simple with almost no pizazz so it can support computers practically back to the Radio Shack TRS-80!
Wow
me too! That machine is what I first learned what "if-then-else" meant back in 1981!
Go old Basic, not even Basica yet.
That TRS 80 brings back memories. There were a few TRS-80s in use in schools when I went through.
My 8th grade general science teacher was Leo Christopherson. This is a name people who remember the TRS-80 might remember--he was a game programmer for the TRS-80. I think he was a fairly well known, once. In any case, I owe a lot to him--my first practical computer experience came in his class. The first time I saw a word processor was in science, when we were required to write up one lab report using the word processor. It seems to me we also used TRS-80s in at least one lab experiment. Contrast this to the math class I had that year which used the same TRS-80 lab--to run a program that was, for practical purposes, glorified flash cards. (This wasn't so much to teach us about math, from what one teacher said. It was so the school could pretend that we were getting "valuable computer experience!" Yeah, right. There is so much need in the real world for people who can effectively run a math flash card program.)
That TRS-80 Model 3 above is exactly what I remember using. The only real difference is that school computer lab did not have floppy drives on the student's computers. (Newer computer users might not know this, but floppy drives were once expensive--hundreds of dollars, not the "it will linger for six months at 99 cents at Goodwill" product they are today.)
Instead of floppy drives, the student computers were connected to the teacher's TRS-80, which had 2 floppy drives. They had two different server systems--one approach that acted like the student computers were loading off a cassette drive (remember those?), and another that allowed them to directly access the floppy drives. The first approach was faster for loading a program--everyone could get loaded at once. The second could only have one student computer accessing the teacher's computer at a time.
I also remember seeing a few TRS-80 Color Computers (the Co Co) floating about. These were for the home market, competing against Commodore C64 and Apple II series. The first computer I ever actually used was a Color Computer, bought as a classroom computer by the PTA.
"I guess I really cannot be too concerned with 12+ year old computers, but maybe I can change the graphics to be more obvious."
Robert, I REALLY appreciate that you are conscious of the problems of older computers, and you're taking reasonable steps to make this site usable. I'm using one that is old, although not 12 years old, and I really appreciate web sites that DON'T cause the system to slow down to the speed of that trickle that I see out of a Kenmore lint filter towards the end of drain. (Originally, I'd thought of using that tired molasses analogy--but this is a washer site!)
Then, there are people here who sometimes run old systems for the fun of it. Come to think of it, it's been a while since I tried this site with BeOS. Hmmm, maybe that can be my weekend fun.
Different "Report" Icons
OK, right now on my browser at home, the "report" icon is the familiar red circle with the white dash. On the browser at work, there is text that says REPORT and some icon I cannot make out. Both browsers are Firefox 3.6.8. Whatz happ'nin'?
In the several hours since my earlier post, the seven-day login expired and I signed in again. Now the browser at home also shows the REPORT and the mystery thing. I guess for some reason I don't understand the icon image on this browser was stale and the check-for-updated-items did not pick it up.
