I don’t know if anyone here is good a basic power supply design, I need a little help since it’s been many decades since I took any design classes. what I'm doing is replacing all the florescent UC lights with leds. I have 3 42" T6 tubes and one 64" T6 tube in addition to 2 small 18" tubes. I've already updated the 2 18" units with 2 sets of 6 3w leds powered from a constant current driver from China. I'm trying to avoid that and build my own with parts I have laying around or from RS.
Anyway, at this point I'm working on the replacement for the 64" unit, it will consist of 16 LEDs. They are 3.6v in series so I need about 57v total to power them at 600 ma. I have a 50v center tapped transformer I'm using, at this point I'm just using one side of it at 25v.
I'm using a design based on this circuit i found on line
<span style="font-size: large;"><span style="font-family: arial;"><span style="font-size: medium;"><span style="font-family: arial;"><span style="font-family: verdana;"><span style="font-family: verdana;"><span style="font-family: times new roman;"><span style="font-family: arial;">
The issue I'm having is the regulator is running quite hot. I'm only driving 8 of the LEDs with it rather than the 16. I'm wondering if I'd be better off using the full 50v feed from the transformer and running all 16 LEDs from it, the current stays constant at 600ma.
I'm open to any other circuit designs that are easy to make at home.
</span></span></span></span></span></span></span></span>
<span style="font-size: large;"><span style="font-family: arial;"><span style="font-size: medium;"><span style="font-family: arial;"><span style="font-family: verdana;"><span style="font-family: verdana;"><span style="font-family: times new roman;"><span style="font-family: arial;">Here are the spec's of the LEDs;</span></span></span></span></span></span></span></span>
<span style="font-family: Arial;"><span style="font-size: large;">Specifications: </span></span>
<span style="font-family: Arial;"><span style="font-size: large;"><span style="font-family: Verdana;"><span style="font-size: medium;">LED Emitter: 3W </span></span></span></span>
<span style="font-family: Arial;"><span style="font-size: large;"> <span style="font-family: arial;"><span style="font-family: verdana;"><span style="font-family: verdana;"><span style="font-family: arial;">- Output Lumens: 180-210 Lumens</span></span></span></span>
<span style="font-family: arial;"><span style="font-family: verdana;"><span style="font-family: verdana;"><span style="font-family: arial;"><span style="font-size: medium;">- DC Forward Voltage (VF) : 3.6-3.8Vdc</span></span></span></span></span>
<span style="font-family: arial;"><span style="font-family: verdana;"><span style="font-family: verdana;"><span style="font-family: Arial;"><span style="font-size: medium;">- DC Forward Currect (IF) : 700mA</span></span></span></span></span>
<span style="font-family: arial;"><span style="font-size: medium;"><span style="font-family: arial;"><span style="font-family: verdana;"><span style="font-family: verdana;">- Color Temp: 2700~3200K (Warm White</span></span></span><span style="font-family: arial;"><span style="font-family: verdana;"><span style="font-family: verdana;">)</span></span></span></span></span></span></span>
