Calling Whirlpool again?
dj-gabriele
Jun 24, 2007
1,685
Hi guys! You might remember about my washer Whirlpool AWO/D 3080, well, it's behaving strange! All of a sudden it started filling waaaay too much in the rinses! It never did this! On sintethics there was more water than in the other cycles but it was around 1-2 cm above the seal level, now, it's up to 3/4 of the drum!!! And it does the same on the other cycles too!
The clothes are more than well rinsed but water usage has doubled. Should I call the service again? Have them check the machine? After all I got it serviced the 18th!!!
WOW....
Much as I like the idea of the rinsing being so great, I would be getting them out again...
...somethings not quite right in Whirlpool land at the moment!
same problem
i have had the same problem with my bauknecht(whirlpool) on synthetics, it filled as high as yours on the rinses but then the pressure switch came in and drained the water and the machine went in alarm. We couldn't wash anymore and a little later it crashed completely.
I would call whirlpool immediately because it isn't normal.
