Calypso Number Two
Finnaly! Goodbye Crapypso and Collapseo! Hello Calypso! I hope the dryer does not need as much work to restore. By the way, how is the Senseon dryer different than a mormal dryer?
Ran into a minor leak problem on the bleach nozzle. Cut a new foam gasket from the sheet left from the u-joint kit, still leaked. Cut two more new gaskets, both together (for more thickness) did the trick.
Dryer disassembly & clean-up in progress. The cabinet had a layer of red lint. The blower won't come loose from the motor shaft, so I pulled the whole thing as a unit. Bunches of debris in the blower housing - bits of broken screws and wire and metal, gravel, dirt, lint, a quarter, a metal washer. Geeze, all this stuff had to been passed through the washer by the previous owners. The foam seal for the lint screen housing must be replaced. Gum or other sticky debris on the drum and rear bulkhead. It's in good condition otherwise, rollers, idler, belt. Barring any surprise electrical issues, it should be quite usable.
Am I seeing what I think I am in the background? Are the Fisher & Paykel washer and dryer gone? Where did they go? What washer and dryer are those? What is the Senseon drying system.
Senseon drying system is unlike the normal whirlpool &kenmore sensor drying systemes, which fluxuate the heating eleament on & of, the senseon system gradually starts high an stays on and drops it's temprature at the end which supposedly increase drying time an energy. It's like a long downhill sloop from high ,medium,low temp and then cool down. That,s it funguy peace Darren k
FunGuy, what do you think you're seeing back there?
It's my KA KAWE760 and GE WWA5600.
Why do think my F&Ps would go away? They may move out of the util room soon so the Calypsos can move in for a while, but as for as going *away* somewhere, no.
BTW, here are the GWL08 and DE04 in my grandmother's garage.
I think the F&P pair deserve some rest and relaxation at Uncle Bobby's winter camp for laundry equipment. They'll get lots of love and attention.
I guess the Fisher & Paykel are going out because the Calypso/Senseon set are DONE!!! Could you post vids of the washer and dryer now?
Very impressive restoration, Glenn.
Quick question: I see there's an F&P toploader Smartdrive L0* for sale cheap locally. Cheap becuase the seller says the "basket is off-tilt". Is that an easy fix?
Ran a Whitest Whites load in the Calypsos Thu night. Used Fab powder, which worked great, minimal sudsing.
The bleach nozzle apparently is leaking again. Noticed some water seepage on the floor by the left rear leg. Grrrr. Can't bring it into the house until that's permanently fixed.
The dryer heats quickly and dries fast, runs quietly. Estimated time (Towels/Cottons cycle) started at 45 mins, promptly dropped to 44, 43, 42, 41, then 28. It backed up once from 19 to 21. Everything was nicely dry except four large bath towels. Recycled them. 45, 44, 43, 42, 41, then 24. It shut off with minimal cool-down shortly after 22 mins, the towels were dry but VERY warm.
Rich, depends on the cause. The tub is hung on springs from suspension rods at each corner of the cabinet (much like the Calypso, except the F&P doesn't have the laterally-mounted shocks at the front). If one of the springs is broken or the rod has shifted from the mount (maybe due to rough handling during a move), shouldn't be a big deal. If, however, one of the molded tub-mounts is cracked, that would require a new tub, or some way to fix/reinforce the mount. I have no idea if that's a common occurrence, I've never had any such trouble with my GWL08. It would be something you'd have to examine before committing to the purchase. Perhaps the Aus & NZ members can comment. There's also a bias spring tied between the front/left support rod to the tub ring to help keep the tub from twisting excessively, but I don't think it would cause the tub to lean if it breaks.
Has your grandma had any problems with the GWL08? Once the Calypso is fixed could you post some videos of it and the dryer?
Calypsos bad washers?
This is my first post, and was just browsing.
I was under the impression from talking to some W'pool dealers that the Calypso was just not a good washer. That is why they went to F&P for the new design.
Anything to this ..or is it really a bargain that folks don't understand, like my old rear wheel drive Volvos?
Thanks
Well, the Calypso washers first came out in 2001 under both the Whirlpool and Kenmore Elite brand-names. The washer was rated by consumer reports as the #1 washer at the time based on cleaning results. There were however, problems and problems with the machine. Problems were most apparent with th U-joint, pump, basket, and electronic control panel. This led to a class-action lawsuit against the machine which pulled the machine off of the market. The machine is now in the phase of being improved and should be re-realeased soon. However, there are thousands of happy Kenmore/Whirlpool Calypso owners who've never had one problem with the machine and others who have had problems with the machine but are still happy to own it. Three members at this site who own a Calypso and are happy with it are DADoeS, bpetersxx, and jaxsunst (if he can ever get his fixed.) It is the machine's unique cleaning-action and current state of rarity that makes it sought after by collectors.
<blockquote>The machine is now in the phase of being improved and should be re-realeased soon.</blockquote>Where'd you hear/read that bit of info?
I didn't think it was being re-released at all. Have not read that anywhere. As much as I love mine, and as great a job as it does at washing, I'm glad it's unique and not on the market any more!! Love the fact that they're so easy to work on.....
Calypso Review
I don't have the whole scoop on the lawsuit and all the common trouble points, but I don't think they're *that* bad of performers in washing ability, or reliability with proper use. Reading through the myriad of complaints on Epinions, I've noticed that many of the reviewers have no clue how the machine works. Some complain about having to always run the Extra Rinse option, and so much extra water being used because of that. They clearly aren't aware that there are multiple rinses (changes of water) in the standard programmed cycles. Extra Rinse only adds one more.
There is a small ick factor with accumulation of lint in the tub ring recirculation port. But it's clean lint!
An array of cycles is provided, but sequences and speeds are fixed within the programs and there's no provision to manually advance the cycle, or to vary the spin speed for example. The Casual/Delicate cycle's wash action is too timid for my typical load of "casual" items so I usually run Normal. I'd like to get a slower spin (500 instead of 800 RPM) but that's not possible. Spin-only allows only 800, and there's no way to select a cycle with a slower spin and advance it to the final spin phase.
Wash time is selected in 1-minute increments between the lowest "Refresh" and highest "Heavy" soil levels, for a range of only 6 minutes difference.
The timed softener dispenser is a bit flaky, sometimes seeping/draining prematurely. IIRC, there was a design revision on it, but I haven't checked if both my Calypsos have the original. Whirlpool used the same detergent/bleach/softener dispenser design on other traditional agitator models so it isn't specific to the Calypso.
Trouble spots that I've noticed are rusting of the dispenser hose clamps and areas under the top, failure of the basket hub, leaking from the bleach injection nozzle, and the rear legs fall out easily, subject to getting broken or lost.
Both my machines are early Whirlpool specimens, built in early and later 2001 per the serial numbers. Design of the u-joint boot and inner wash plate seal was changed during that time. My older machine has the original style, the newer machine has the revised style. I doubt the older machine has been cracked open because it would likely have the revised style if it had needed replacement. I've not had a direct look at the u-joint, but I've pulled the outer dome and there's no evidence of rusting or muck visible through the translucent inner wash plate. Considering it sat for some months at a resale shop (dunno where it was before that) along with time between my uses of it, I figure the u-joint would have frozen-up or exhibited trouble by now if the seals have failed ... so apparently they're intact.
As for the HE factor ... I've gotten accustomed to the F&P being frugal with *hot* water, and enjoy the Calypso on that point as well. The idea of filling a tub with hot or warm water gives me pause now, LOL.
Great review
Thanks, Glenn. I saw a 2000 vintage (?) Calypso for sale recently for $50, but passed on it mostly due to washer overload (too many washers, not too many overloaded washers).
The one I'd really like is the HE Cabrio with the clear lid. That would be fun to watch!
