Can anyone help?
sudsdudeshane
Jul 17, 2006
145
I really want to buy a front load washer but I would like a front loader that uses a bit more water than the ones I have been seeing. It seem so many of them use so little water when they wash..any suggestions?
It was my understanding..
that the reason for the lower water level (other than the obvious water savings) was that the clothes actually get cleaner in less water. I think someone here explained it one time. I guess it has to do with how the clothes hit the tub as they tumble and with more water they get somewhat cushioned.
My Bosch FL doesn't use that much water in the wash and my clothes are cleaner than they ever were in a TL. Why do you want one that uses more water?
Lower level
No so many years ago we washed in 12 or 14" of water in our plant however over the past 5 years or so it has been found the not only does it save water to drop the level it saves detergent and clothes really do come cleaner as the drop in the machine is not restricted our 125 lb machine only washes in 4" while the 50s and 75 only use 2" and do a great job.
125 lb
Wash level at one time was 8 or 9 " now we wash in only 4" and get very good work. Even on heavy soil blood work it comes clean in less water.
What is the dosis required, Louis?
I have to agree that psychologically a "wipe wash" does not appeal to us Americans used to PLENTY of water. But the clothes do come out clean when using a front-loader [ok ok call off the mob ready to do a lynching, now... LOL] and I can't detect any build-up of chemicals, soils etc.
I suppose the key is to properly dose the chemicals and to use waxy softeners VERY VERY sparingly and infrequently, IMHO.
When on thinks about it, front loaders will clean better with less water inthe wash (IMHO, this has limits), because the washing action is both mechanical (beating laundry against the drum), and allowing the concentrated detergent/water solution to flow through laundry (during the pauses).
Tumbling laundry round and round in lots of water is not good for washing, unless one is laundering delicates or woolens. In which case you want a more gentle washing action, and less stress to laundry. Duvets, pillows or other items that then to float and are difficult to get evenly wet, also require more water.
You want low water levels for washing, and high for rinsing. Problem is once one starts going down the "wet wipe" path of laundering, chemicals play an more important role. Too much of any sort of chemical in the wash will be that much more difficult to rinse away.
L.
I noticed that the other day..
I was washing a jacket that called for a delicate cycle. At one point I noticed there seemed to be more water in the tub that I am used to. I almost thought it was a rinse.
