Can you balance fan blades by yourself?
classiccaprice
Jun 26, 2007
2,059
Hampton, Virginia
I bought a cool space age fan today (I'll try to post a pic tomorrow), however the blades are out of balance. Anyone know how I would go about fixing that? Thanks!
Some of my fans have included a balance kit, a small weight that attaches to a blade, with a test procedure outlined to determine on which blade and where to place it. The same thing could be done with any small object(s) (coins, washers, etc.). You MUST be sure the balance-weight is SECURELY fastened.
Leave it to a pro
Yes you can certainly attempt to "balance" a fan blade but you could easily end up with something worse than when you started.
Fortunately there's a "www.fancollectors.org" club, a number of members who do such work as rewind motors, balance blades and repaint antique models as a business. Depending on what you spent, the construction of the blade, (stamped aluminum, brass or other metal riveted to a cast iron hub or even bakelite or rubber), you may decide that a slight corrective bend on one wing of a dime-store fan will make you happy or accidentally causing a crease in a rare brass blade will devalue your investment.
Along with simply bending one blade forward or back to solve your problem, there may also be an out-of-clock situation whereby a blade may have been forcefully stopped against an object, thus bending it away from the adjacent blade, harder to see but also capable of causing vibration of a different type.
One way to approach a simple bend is to remove the blade and attach it to a shaft of a drill press. By lowering the blade horizontally down toward the table you can see which blade is not in line and can bend one or all to the same pitch. Another tedious method is to leave the blade on the motor and use the front and back guards to measure distance away from perfect center with a ruler. There can also be the use of an auto timing light to isolate the offending blade, marking the spot with crayon while in motion so it can be isolated. Then there's the matter of shaving a weight off a blade or adding solder to achieve no vibration. A lot of things to think about depending on your investment and available time.
First thing I'd do is see the website. Questions are accepted from non-dues-paying members and there are people willing to walk you through the process. Best of all, it can be a useful collectible!
Fans
Classiccaprice is a friend of mine from college. It's a portable fan, not a ceiling fan. I have the Antique Fan Collectors' Association link in my AW.org profile for anyone who wants to see. I know that in order to properly balance fan blades, you need a strobe light and a light touch. I don't have the equipment or the experience to do it myself, but I wish I did. I have many old fans which I use, and they are all balanced (whew!). The best-performer I have is a 1947 GE Vortalex, but I hear they are very difficult to balance.
Keeping our old appliances running is a labor of love that takes an entire community. It's worth it though,
Dave
