Can you identify these controls?
I wonder if the air pump has anything to do with the automatic load size feature advertised for this model?????? Using air displacement on a more sophisticated level to sense load size to use enough water?????
Frigilux.... OR Gansky1
"Frigilux":
But then, on the same token, I have every reason to believe that there were liquid detergents available in 1960 also. But then, that alone was going to throw a monkey wrench to yet another problem.
If you were to go ahead and use a liquid detergent with the 1960 Lady Kenmore (just so that you can use the dispenser), because of a lack of a continuous water feed (as was found in the later Lady Kenmores), any liquid detergent that was not dispensed into the tub by the washer could've just dried up and become gummy eventually clogging the dispenser, right??
Greg, feel free to take this one on if you like..... :)
--Charles--
Aside from the question that I have asked today.....
Greg:
You have to show both the washer and dryer together when the renovation of the washer is complete.
That's going to be a beautiful set.
But then again, that was your dream set all along, wasn't it???
--Charles--
"If you were to go ahead and use a liquid detergent with the 1960 Lady Kenmore (just so that you can use the dispenser), because of a lack of a continuous water feed (as was found in the later Lady Kenmores), any liquid detergent that was not dispensed into the tub by the washer could've just dried up and become gummy eventually clogging the dispenser, right?? "
Oh, you're just going to LOVE the dispensers.... Soon, I promise!
